Chris - Burman Posted April 6, 2009 Report Share Posted April 6, 2009 how can i speed up the bedding in process of a hope mono trial,for example, with a cable disk brake, you make the disk/caliper really hot, then you poor water onchris Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted April 6, 2009 Report Share Posted April 6, 2009 Ride around with the brake on. Or find a big hill and really drag the brake. Quote Link to comment Share on other sites More sharing options...
weirdoku Posted April 6, 2009 Report Share Posted April 6, 2009 (edited) with a hydraulic disk brake, you make the disk/caliper really hot, then you poor water on Edited April 6, 2009 by weirdoku Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted April 6, 2009 Author Report Share Posted April 6, 2009 so you do just the same Quote Link to comment Share on other sites More sharing options...
JonMack Posted April 6, 2009 Report Share Posted April 6, 2009 ZING! Quote Link to comment Share on other sites More sharing options...
Muel Posted April 6, 2009 Report Share Posted April 6, 2009 Add Mud. It beds it in faster, just doesn't give quite as good results.The best way I've found is to get it good enough so you can ride it, then just ride it and it will bed in as you ride. Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted April 7, 2009 Author Report Share Posted April 7, 2009 Add Mud. It beds it in faster, just doesn't give quite as good results.The best way I've found is to get it good enough so you can ride it, then just ride it and it will bed in as you ride.you shouldt say that, some poor sod will put mud ll over it lol Quote Link to comment Share on other sites More sharing options...
JonMack Posted April 7, 2009 Report Share Posted April 7, 2009 It's true, loads of riders do it. Quote Link to comment Share on other sites More sharing options...
Muel Posted April 7, 2009 Report Share Posted April 7, 2009 Lol, you think I'm joking? I've done it to every disc brake I've had for the last 5 years, I believe Boumsong has aswell.Do it the hard way if you like just with water! It will take ages and often goes wrong and glazes the pads in mono trial brakes I've found. Quote Link to comment Share on other sites More sharing options...
