gu trials Posted April 6, 2009 Report Share Posted April 6, 2009 as the title says, i have been getting headaches whilest got my helmet on and when i take it of my head is a little sore, i think it may be the padding being to thin so the plactic piece is digging into my forehead but not sure .can anybody help ?? Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted April 6, 2009 Report Share Posted April 6, 2009 My giro e2 used to do this.....just above my foreheadi just added extra padding in that spot and job done dave Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted April 6, 2009 Report Share Posted April 6, 2009 maybe wearing it too tight???extra padding sould do the job!I used to get real bad head aches.... I cut coffee out my diet and nothing nowa days.Hydate more??? Quote Link to comment Share on other sites More sharing options...
Tomm Posted April 6, 2009 Report Share Posted April 6, 2009 Hydate more???That would be my guess. A helmet rubbing might make the skin sore but that's not really a headache? Quote Link to comment Share on other sites More sharing options...
Hendrix Posted April 6, 2009 Report Share Posted April 6, 2009 I occasionally get a headache from wearing my helmet too tight, or if it rubs too much in one spot. All of the above have been countered by drinking loads of water/what ever during the day, and maybe carrying some painkillers. Quote Link to comment Share on other sites More sharing options...
Gandalf the Yellow Posted April 6, 2009 Report Share Posted April 6, 2009 too tight. the adjuster on the back (where available should be just firm so don't pinch it hard together to get few extra clicks.and straps need to be loose enough so you can fit 3-4 fingers between your head and strap. if you still get headaches then extra padding where its hurting...last resort: the helmet just isn't right for you and time to invest in another. not all helmets fit everyone nicely!steve Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted April 6, 2009 Report Share Posted April 6, 2009 Yep everyone has a different size and shape of head.Same when it comes to buying motorbike helmets, the same size can be a completely different fit between two different makes.Loosen it off, check the padding and make sure there are no sharp or proud edges in the plastic underneath.Worst comes to worst, just buy a new helmet. =D Quote Link to comment Share on other sites More sharing options...
mountian goat Posted April 7, 2009 Report Share Posted April 7, 2009 try wearing a hat/beanie under the helmet works for me but its not to nice on a hot dayo and try only wearing it when you are actually riding som it stays off your head for a while hope i have helped lee Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted April 7, 2009 Report Share Posted April 7, 2009 (edited) This may seem odd but what i did is put it on and slacked it until i can smile with my teeth out then it gives abot of slack so you don't squash your head (which may be your problem) but doesn't fall off Edited April 7, 2009 by Jamie_Trials Quote Link to comment Share on other sites More sharing options...
hdmackay Posted April 9, 2009 Report Share Posted April 9, 2009 (edited) I sometimes get headaches when i'm out riding but I thought it was just from riding too much! My helmet isn't that tight though so maybe it is from that.It gets quite sore when I go to front alot? I find the best way is to just rest for a bit. Edited April 9, 2009 by hdmackay Quote Link to comment Share on other sites More sharing options...
