George.E Posted April 6, 2009 Report Share Posted April 6, 2009 Could anyone please tell me the torque setting for the rear HS33 4bolt mount ?Thanks Quote Link to comment Share on other sites More sharing options...
forteh Posted April 6, 2009 Report Share Posted April 6, 2009 Could anyone please tell me the torque setting for the rear HS33 4bolt mount ?ThanksDont bother, just dont go silly and use the allen key properly Using a long series allen key you shouldnt need to use any more than finger strength to tighten them, dont use your wrist and arm to do it or youll strip it out pretty quickly.Normally once the gap between the top and bottom mount is closed up thats tight enough. Quote Link to comment Share on other sites More sharing options...
spaceman Posted April 7, 2009 Report Share Posted April 7, 2009 I believe it also quite depends on how "worn-out" the cylinder washers are.I stripped one of the mounts cos I thought it needed to be tightened really tight! Quote Link to comment Share on other sites More sharing options...
