BigAl Posted April 5, 2009 Report Share Posted April 5, 2009 Okay, so i got a puncture, walked my bike home and tried to get my rear wheel off. I got the non drive side bolt out no problem, but the drive side bolt refused. All i ended up with is a rounded bolt, a stuck wheel, and a cut finger. Anyone got any ideas on how to get the bolt out? Its an iron or steel bolt in an Echo TR hub.Need help pretty urgently:)Thanks.Alex Quote Link to comment Share on other sites More sharing options...
onzatrip Posted April 5, 2009 Report Share Posted April 5, 2009 make a slit in the bolt then use a big screw driver to get it out then replace it with a new bolt!!hope ive helped tris Quote Link to comment Share on other sites More sharing options...
BigAl Posted April 5, 2009 Author Report Share Posted April 5, 2009 How would i make a slit? And its done up really tight, im going to need alot of leverage to get it out.Alex. Quote Link to comment Share on other sites More sharing options...
JackC123 Posted April 5, 2009 Report Share Posted April 5, 2009 make a slit in the bolt then use a big screw driver to get it out then replace it with a new bolt!!hope ive helped trisumm......Get an angle grinder with a really thin disk, cut a slit into the nut and use a flatheard screwdriver to get it out. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted April 5, 2009 Report Share Posted April 5, 2009 How would i make a slit? And its done up really tight, im going to need alot of leverage to get it out.Alex.with a saw across the bolt then use a big screwdriver works a treat!tris Quote Link to comment Share on other sites More sharing options...
Muel Posted April 5, 2009 Report Share Posted April 5, 2009 I've never got that to work, you can't turn the screwdriver hard enough and it keeps jumping out of the slot because you can't cut deep enough without damaging the wheel bolt spacer washer thing. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted April 5, 2009 Report Share Posted April 5, 2009 I've never got that to work, you can't turn the screwdriver hard enough and it keeps jumping out of the slot because you can't cut deep enough without damaging the wheel bolt spacer washer thing.worked for me in my old tryall hub try jamming the screw driver in the allen key bolt slits first Quote Link to comment Share on other sites More sharing options...
BigAl Posted April 5, 2009 Author Report Share Posted April 5, 2009 Im not bothered about damaging the bolt and spacer, I have spares, I just want it off, so i can go out and ride:)Alex. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted April 5, 2009 Report Share Posted April 5, 2009 Im not bothered about damaging the bolt and spacer, I have spares, I just want it off, so i can go out and ride:)Alex.go do it then mate!! Quote Link to comment Share on other sites More sharing options...
DaNnI BoI Posted April 5, 2009 Report Share Posted April 5, 2009 Not sure if this will work because i havnt tried it myself.But try holding the end off the bolt with a pair of mole grips. but make sure they are done up realy tight.Then try twisting the bolt off.Hope this helps you.Dan Quote Link to comment Share on other sites More sharing options...
Dave! Posted April 5, 2009 Report Share Posted April 5, 2009 When you say rounded off, do you mean the allen key slot or the threads?Sealed hubs can also be annoying, you tried tightening the non dirve side back up and then trying the drive side again?If that isnt the case then making some sort of slot for a screwdriver/lever? Quote Link to comment Share on other sites More sharing options...
shamus Posted April 5, 2009 Report Share Posted April 5, 2009 grind the bolt edges to oblivion witha grinder until you can get a spanner on it, its destructive and brutal but it can work as a last resorttake care not to carve up you frame as well though.good luck bud Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted April 5, 2009 Report Share Posted April 5, 2009 file down the two sides to you can wack a spanner on there always works for me! Quote Link to comment Share on other sites More sharing options...
BigAl Posted April 5, 2009 Author Report Share Posted April 5, 2009 Should have been more specific, it was the bolt head that was rounded, its all sorted now. In the end i hammered it down the dropout, took the chain off, and then used all my hammering force to bash it out the dropout, took me a few minutes but i got it done:)Thanks for all the help guys.Alex. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted April 5, 2009 Report Share Posted April 5, 2009 Should have been more specific, it was the bolt head that was rounded, its all sorted now. In the end i hammered it down the dropout, took the chain off, and then used all my hammering force to bash it out the dropout, took me a few minutes but i got it done:)Thanks for all the help guys.Alex.Works with me what ever im going..if in doubt.......get a hammer Quote Link to comment Share on other sites More sharing options...
JackC123 Posted April 5, 2009 Report Share Posted April 5, 2009 Works with me what ever im going..if in doubt.......get a hammer Haha sig'd. Quote Link to comment Share on other sites More sharing options...
JackDolan Posted April 6, 2009 Report Share Posted April 6, 2009 bray the next size allen key in the bolt woth a hammer and then just loosen it,if not just try and slit it. Quote Link to comment Share on other sites More sharing options...
