Small Mechanical Questions
Revolver
I thought this might be a good idea, lol.
This thread is for those small questions that don't need a full thread to answer them or discuss them.
Here's one to start us off!
My chain skips on my gears. I've got the 8sp kmc kool chain, new, on a used cassette. I've only got two gears, spaced out a bit so the chain fits. I can use the lower of the two, 16t, fine, but not the harder, 13t. Why? I suspect I might need to take a link out of the chain? It can't be that it's not bedded in, as it works in the other gear.
No matter what I do my BB wont stop creaking. I've taken everything out about 4896058367035489 times, greased EVERYTHING, cleaned EVERYTHING, greased EVERYTHING again, and it still creaks. The only thing I've changed is crank bolts, and frame, could it just be the BB settling into the frame?
please Jon dont shoot me, But have you got grit in your pedals ?, last time it happened to me i took my bike (spec p1) to the lbs and they said you'll need a new BB i went home cleaned every thing (the pedals aswell) and it stopped creaking.
p.s. i had grit and snad in my pedals.
Thus, if I take a link out of my chain, it should increase the tension and wrap around, and stop skipping?
That may not solve the problem. What I meant was the larger cog means it has more area to connect too, meaning that it is less likely ot slip on worn cogs, however the 13tooth cog has less raparound space.
Maybe, I'll check them out :)
Same here, I have new pedals, new BB. Greased frame before putting BB in and still does it, took BB out cleaned it greased it, still creaks. It feels like it's from the BB area, when I spin the BB with my hands it's smooth and so is the pedals.
I'm just ignoring it for now but would like to know how to stop it!
Mine does it too - someone said (can't remember who), that it could be to do with the chain line?
It's your knees mate... the haven't any fat or muscle around them to muffle the creaking noises... like mine :D
:P probably!!
Yeah I've done all of that, it only creaks when I put power down, it's kinda like the last 1/4 of the right hand pedal stroke, but to be honest I can live with it.
Chain line is as good as it can be. Monty ISIS cranks, 18t Surly sprocket, 124mm Fsa Platinum Pro BB, CK ISO BMX hub :(
My only creaks when either crank is pointing vertically down, with power or just standing on my pedals and slowing pedaling along.
Could it be the BB cups being slightly smaller than the actualy BB area in the frame? Small enough to not notice by hand but noticeable when weight is put on the BB? Hence the creaks?
This thread was deffinately needed.
Shifter pull/mech movement doesn't equal the distance the sprockets are spaced out properly?
I've set it up so it works, the jockey wheels and the cassette sprocket are both aligned properly, it just skips.
The wraparound might be why. I'll keep riding it, I'm taking that link out, so long as I can.
Old both, worked perfectly two weeks ago in my old bike.
Looks like next paycheque is gonna be dropped on a new BB then. Reset Ti anyone?
If that was a question to who wants one, I will please :)
Does the creak do any kind of damage to the frame though? If yes I'll replace my BB as well.
