Hope Trials Brakes
Hiya peoples. Some help please. At the moment I'm using an Avid bb5 disc brake on the front of mi Echo, but I dont trust it to lock the wheel when doing frontwheel hops. So its time for a change & I keep hearing the Hope mono trials brake is the one to buy. My ? is. Is it the muts nuts & will I be able to trust it to lock the front wheel, without nearly having to break my finger, pulling the lever so hard?
I wouldn't recommend it if you're a beginner because you will fall off and break it, And be gutted. Get a magura Louise if you're a beginner. Although if you're not go for it a mate of mine has one and they are amazing brakes.
thats how you learn :$
Hey, I used to run a hope, was a really good brake. But, when i got a new bike, I switched to a Magura Louise. To be honest, I think the Louise is better if you are a beginner because it is a very sturdy and tough brake, whereas the Hope ones aren't quite as tough.
Magura Louises are also cheaper, which is an added bonus. You can get one off here for around £40- £50 I think. So, overall, I would definitely go with the Louise if I was you. :)
More like £20, hopes on here go for £40-60
my avid bb7 is as powerfull if not more than many hydrolic brakes ,plus the complete set-up is like £70 ,if it's possible i'd reccomend you try someones bike that has a bb7 on it to find out for yourself (Y)
+1
if you are struggling with the bb5 then there is something wrong with it, I consider them to be more powerful than a Hope, but with more maintenance and heavier.
My thoughts exactually, i got rid of my hope because my bb5 had so much more power.
