Hope Mono Trial Problems
stoozie
Nah, just forget about it. It might have something to do with the forks, I'm guessing it's a stock wheel?
It might be that you need to apply more pressure to the pads because the ratio between rotor and wheel size is much larger than when I had my 160 on a Mod.
Maybe try a 200?
A 160 Hope rotor.
Is it something wrong that I should worry about? Or is it something that just seems to happen with them?
I would say that you need to face your brake mount.
If there is excessive paint or metal on your brake mount, it doesn't allow for the calliper to sit exactly parralel with the rotor (which is very important).
Of course what happens there is that a small amount of pad contacts the rotor first, followed by the remaining pad. (Much like with standard vee brakes on £200 mountain bikes, if the pads aren't set properly square it can create the some kind of squeak).
Hope do a mount facing tool, which slips into your drop out and essentially files away at excessive paint or material to create a perfectly parralel mount.
Most specialist bike shops will carry one.
On a related note, what is your wheel alignment like? (is it front or rear brake) if its your rear wheel then it may not be central so the rotor itself isn't parralel to the calliper.
It's really high pitched, (scared the hell out of people when I braked at the end of an allyway yesterday). The power hasn't changed at all, still really good. It's just the noise, I want to know if something is wrong, or if its just something that happens
