Euro Bb
sstein
I "think" euro is the thread size/type. 68-73 is just the width of the shell, they'll both take the same bb's.
In the uk we all use euro bb. If its for a Marino frame then yes you ask for euro
Leon
Edited by LEON
There's this thing on the internet which allows you to search loads of different sites and get loads of info.
I THINK it's called google?
I do believe that is a bit harsh. He asked a genuine question and this thread actually helped me understand cause i didnt know either.
I THINK it's called Trials forum?
Euro BB in bmx terms don't have threads, there like headsets there press in. This may be different for other things though.
The Euro bit signifys the size of the acctual bearing, theres euro, spanish just to name a few.
Theres a topic on the "other" forum, explaining it.
Heres a link.
http://www.bmx-forum.co.uk/forum/index.php?showtopic=3019
I'm not sure if this is what your looking for but i hope it helps in some way.
This is an example of what i mean although looking i have seen threaded euro bb's.
http://www.alansbmx.com/product_info.php?c...roducts_id=2270
Heres a link.
You're wrong.
There's US, Mid, Spanish, and Euro.
This is a BMX Euro BB
Threaded cups with bearings, but no axle, because that's part of the cranks. The bearings will either be 19 or 22mm ID.
First of all I did search google, but found mainly products not answers (crc sucks at spec details).
I am pretty sure that euro is 68mm english threads, but I just wanted a second opinion before I had two frames made with the wrong type of bb.
As for it being the size of bearing that is not quite true. There are many types of bmx bb (usa, spanish, mid, euro) and they all use the same two inner diameter of bearing i.e. either 19mm or 21mm (I think). The type of BB refers to not just the outer beaing diameter, but also bb width and installation style, e.g. press fit, standard thread or reverse thread.
I know I pretty much answered my own question, I just wanted to check with other people before marino builds my frames.
You're wrong.
I'm not wrong there are different types I just got the wrong type sorry. i know for a fact what i said is also sorrect because i am sitting here with a push in euro bb that i've taken out of my bike, but yer obviously got the wrong end if the stick, sorry.
