DannyBaz Posted April 1, 2009 Report Share Posted April 1, 2009 Hey, i popped my freewheel the other day, and bought a replacement off tarty bikes (acs claw 18t) and it has just come. But the problem is, i cant get my old freewheel off. Because it was popped, the chain ring piece has already dropped off, and i have just the screw on bit left attached to the tensile cranks. Also, i don't have a freewheel tool.Can anyone help me with this? Is there a way to remove this piece without tools ? Thanks Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 Come on, Someone must know how! Quote Link to comment Share on other sites More sharing options...
Headley Posted April 1, 2009 Report Share Posted April 1, 2009 What make of freewheel is your old one? I've got a tool, so I might be able to remove it for you. Quote Link to comment Share on other sites More sharing options...
LiamWood! Posted April 1, 2009 Report Share Posted April 1, 2009 If all the internals of the freewheel are off, just clamp up whats left in a vice get a fairly long steel tube (scafoulding bar will do the job) slide it over the end of the crank arm and turn.Should come off fairly easy, also what freewheel did you have before? Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 What make of freewheel is your old one? I've got a tool, so I might be able to remove it for you.Thought you didn't like me Headley? Thats what Jake said anyway. I will just find out what make hold on. Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 Its an ACS claw but it looks quite an old one.. Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 I tried putting it in a vice and turning with a pipe, but it just kept slipping. So Headley, could i borrow that tool or wouldn't it fit ?I added you on MSN anyway so i will talk to you on there. Quote Link to comment Share on other sites More sharing options...
Daveee Posted April 1, 2009 Report Share Posted April 1, 2009 I tried putting it in a vice and turning with a pipe, but it just kept slipping. So Headley, could i borrow that tool or wouldn't it fit ?I added you on MSN anyway so i will talk to you on there.The freewheel on that T-Mag is tensile I think. Quote Link to comment Share on other sites More sharing options...
WIGAN Posted April 1, 2009 Report Share Posted April 1, 2009 If clamping it in the vice and turning the crank wont work, heat it up with a blow torch or summert then try it . Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 Dave, it was an ACS claw i just found the bits and it said so on it lol.If clamping it in the vice and turning the crank wont work, heat it up with a blow torch or summert then try it .I'm 14, where would i get a blowtorch from ? Quote Link to comment Share on other sites More sharing options...
WIGAN Posted April 1, 2009 Report Share Posted April 1, 2009 I'm 14, where would i get a blowtorch from ? Well i dunno make a fire in the garden, just heat it up somehow trust me it will come right off. Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 Well i dunno make a fire in the garden, just heat it up somehow trust me it will come right off.Think i could do it with a lighter? Or wouldn't it be hot enough? Quote Link to comment Share on other sites More sharing options...
mr ailsbury Posted April 1, 2009 Report Share Posted April 1, 2009 (edited) clamp the bit you need to get off it the vice and smack the crank arm rounf with a rubber malletbrawn *** Edited April 1, 2009 by mr ailsbury Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 clamp the bit you need to get off it the vice and smack the crank arm rounf with a rubber malletbrawn ***All ready tried that, just kept slipping out. I will try again though Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted April 1, 2009 Report Share Posted April 1, 2009 All ready tried that, just kept slipping out. I will try again though If you can't get it off by tonight (no pun intended...) just bang it in the freezer over night then first thing in the morning boil it in a pan. Should be able to bar' it off then Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 If you can't get it off by tonight (no pun intended...) just bang it in the freezer over night then first thing in the morning boil it in a pan. Should be able to bar' it off then Thanks Pashley, will give that a go if nothing else works Quote Link to comment Share on other sites More sharing options...
D A N N Y Posted April 1, 2009 Report Share Posted April 1, 2009 (edited) My old bike how did you break it ? Edited April 1, 2009 by D A N N Y Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 My old bike how did you break it ?Don't know, was just riding and it all fell apart Quote Link to comment Share on other sites More sharing options...
ding_dong Posted April 1, 2009 Report Share Posted April 1, 2009 sounds like the lockring had come loose whilst riding it causing the internals, and outer for that matter to fall off, its a common fault with acs freewheels, where as the tensile has a reverse thread on the lockring as its specialy made to be used on the front, so all it will do during riding, if anything, is tighten Quote Link to comment Share on other sites More sharing options...
Headley Posted April 1, 2009 Report Share Posted April 1, 2009 (edited) I havn't got the right tool to remove it but I know a couple of people that might have one. Edited April 1, 2009 by Headley Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted April 1, 2009 Author Report Share Posted April 1, 2009 I havn't got the right tool to remove it but I know a couple of people that might have one.Ok, thanks Headley.. i might not need it now though.. i have put it in the freezer like that guy said to. But if i do need it i will let you know thanks Quote Link to comment Share on other sites More sharing options...
sstein Posted April 1, 2009 Report Share Posted April 1, 2009 If it is slipping when you turn i, you need to tighten the vice up more. I do this all the time. I have even done it with working freewheels and it worked. Quote Link to comment Share on other sites More sharing options...
Annihilation Posted April 1, 2009 Report Share Posted April 1, 2009 Either bolt the tool to the crank arm, put the tool in the vice and a tube on the crank and turn, OR, put the crank arm in the vice, bolt the tool on, and use a massive wrench.That should do the trick You need a vice that's not going to move, mine is loose, which is useless. You could also just cut the old freewheel off with an angle grinder, but you must be careful doing this, not to wreck the threads. Quote Link to comment Share on other sites More sharing options...
Dave! Posted April 1, 2009 Report Share Posted April 1, 2009 I once cut a freewheel off with an angle grinder, went into the threads but they still worked. Would'nt recommend it though.Why not just take it to your LBS and get them to do it. They normally have more tools and the workspace, and its just easier. Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted April 1, 2009 Report Share Posted April 1, 2009 If you're really stuck, take apart the freewheel, grind flats on either sides of the internals, then clamp that in the vice.It's a bodge, but every question has an answer. Quote Link to comment Share on other sites More sharing options...
