catman-al Posted March 31, 2009 Report Share Posted March 31, 2009 HI am new to trials and was thinking of getting a brake booster for my mod , but i don't know wether i should go for a 2 bolt or 4 bolt booster. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted March 31, 2009 Report Share Posted March 31, 2009 4 bolt boosters are usually stiffer, making the brake feel more solid. Added weight though. Do you really need a booster though? Try setting your brake up so the pads hit the rim perfectly flat, if the frame still flexes, then get a booster.I say if it flexes a lot, get a 4bolt, if it's only flexing a little, get a 2 bolt. Quote Link to comment Share on other sites More sharing options...
George.E Posted March 31, 2009 Report Share Posted March 31, 2009 I would say 2 bolt as there a tiny bit lighter. Quote Link to comment Share on other sites More sharing options...
Daveee Posted March 31, 2009 Report Share Posted March 31, 2009 4 bolt boosters are usually stiffer, making the brake feel more solid. Added weight though. Do you really need a booster though? Try setting your brake up so the pads hit the rim perfectly flat, if the frame still flexes, then get a booster.I say if it flexes a lot, get a 4bolt, if it's only flexing a little, get a 2 bolt.Lighter by like 10g lol, I'd say go for 4 Quote Link to comment Share on other sites More sharing options...
DannyBaz Posted March 31, 2009 Report Share Posted March 31, 2009 Come on, whats about 10-20g? Go for a 4 bolt, they look nicer, and are much sturdier and stop the frame flexing more than 2 bolts which don't really stop it flexing at all, depending on which one you buy. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted March 31, 2009 Report Share Posted March 31, 2009 Seriously a 2 bolt trial tec booster eliminates flex Quote Link to comment Share on other sites More sharing options...
siyross Posted March 31, 2009 Report Share Posted March 31, 2009 If you are using V brakes then you can only fit a 2 bolt booster anyway. Get the best you can. A 4 bolt booster is going to be a lot stiffer than a 2 bolt one Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted April 3, 2009 Report Share Posted April 3, 2009 when i had my magura brakes i had a 2 bolt and a 4 bolt boosters on it it was really good , ''if you dont care about a couple of grams '' Quote Link to comment Share on other sites More sharing options...
Muel Posted April 3, 2009 Report Share Posted April 3, 2009 I'd get a 2 bolt, 4 bolts take more of the bite away in my experience. Quote Link to comment Share on other sites More sharing options...
catman-al Posted April 7, 2009 Author Report Share Posted April 7, 2009 Thanks for the advice guys. Am going to go for a two bolt as there isn't alot of flex. Quote Link to comment Share on other sites More sharing options...
mike-dyson Posted April 7, 2009 Report Share Posted April 7, 2009 I've got a 4 bolt booster but I've only got 2 bolts in it, works really well i just need some bolts and spacers! Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted April 8, 2009 Report Share Posted April 8, 2009 Ive recently just bodged some of those wee tiny magurs boosters to fit onto my mod. Got them front and back and i must say, They are doing just as good as my old Echo Team booster and that thing is massive. So i reckon a 2 bolt will be great in most cases. Quote Link to comment Share on other sites More sharing options...
gage-mann Posted April 8, 2009 Report Share Posted April 8, 2009 i found a two bolt booster easyier to deal with and the brake just felt the same as it did with a 4 bolt. i had used a two bolt ZHI booster and a 4 bolt echo booster, both are very good Quote Link to comment Share on other sites More sharing options...
Ali C Posted April 8, 2009 Report Share Posted April 8, 2009 I found no noticeable difference in feel between a 2bolt and 4bolt booster.I am currently using a Trialtech carbon booster and its REALLY stiff! I would always recommend a booster even if you have a stiff frame, the improved brake hold is worth it for sure! Plus its harder to break the cross over. Quote Link to comment Share on other sites More sharing options...
bigamac Posted April 8, 2009 Report Share Posted April 8, 2009 I will depend on what frame you have to what difference it will make because each frame gives a different amount of flex. Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted April 8, 2009 Report Share Posted April 8, 2009 How would i modifie the magura evo2 2 bolt brake booster to get wider Quote Link to comment Share on other sites More sharing options...
