hdmackay Posted March 31, 2009 Report Share Posted March 31, 2009 Hey guys,Today I noticed my bashplate was squint and then when I looked at it I saw that a bolt was missing. But i've now realised that the bolt actually snapped and the other bit of the bolt is now stuck in my frame!Does anyone know a way to get it out?Does anyone know a bodge I could do to keep that big of the bashguard tight because the rubber keeps falling out now.I don't want to take it off because I will just destroy my frame.ThanksHunter Quote Link to comment Share on other sites More sharing options...
Sam Ward Posted March 31, 2009 Report Share Posted March 31, 2009 yeahh stop being a basher, its a bashguard not a 3rd wheel which is most probably the reason it broke in the first placebest fix would be to drill the bolt out and put a new one in, or if theres a bit of bolt hanging out use a hacksaw cut a small slot in it and use a screwdriver to undo it, then replace the boltpersonally id just stop using it Quote Link to comment Share on other sites More sharing options...
JonMack Posted March 31, 2009 Report Share Posted March 31, 2009 Sam's right really. Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted March 31, 2009 Report Share Posted March 31, 2009 had enough problems of this nature.how much of the bolt is pocking out of the frame? if you got 3-5mm tall head showing you might be able to saw down the middle of the bolt(trying not to saw the frame) and use a flat head screwdriver?other wise drill the bolt out and retap....only ever done that on brake mounts though and thats only 4mmupto5mm.the ones on the bash are 6mm arn't they.....or 5mm can't remember?!?!?!? Quote Link to comment Share on other sites More sharing options...
JonMack Posted March 31, 2009 Report Share Posted March 31, 2009 Could drill/helicoil it. Quote Link to comment Share on other sites More sharing options...
psycholist Posted March 31, 2009 Report Share Posted March 31, 2009 Have a look on internet for ez-outs... Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 31, 2009 Author Report Share Posted March 31, 2009 personally id just stop using itSam's right really.I honestly would destroy my frame in about a week though. Quote Link to comment Share on other sites More sharing options...
Sam Ward Posted March 31, 2009 Report Share Posted March 31, 2009 you'll destroy your frame even if you have got a bash on there by the sounds of it, and at the moment you hav'nteither fix it like we've all recommended you do, none of the fixes are hard, OR ride smoother and don't go for stuff you clearly cant do Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 31, 2009 Author Report Share Posted March 31, 2009 how much of the bolt is pocking out of the frame? if you got 3-5mm tall head showing you might be able to saw down the middle of the bolt(trying not to saw the frame) and use a flat head screwdriver?other wise drill the bolt out and retap.Theres a wee bit sticking out, but it's on the under-side bit under the frame.So it would be a bitch to get to. Quote Link to comment Share on other sites More sharing options...
Sam Ward Posted March 31, 2009 Report Share Posted March 31, 2009 pics?? Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 31, 2009 Author Report Share Posted March 31, 2009 (edited) you'll destroy your frame even if you have got a bash on there by the sounds of it, and at the moment you hav'nteither fix it like we've all recommended you do, none of the fixes are hard, OR ride smoother and don't go for stuff you clearly cant doI will try what yous have said but I mean, quite often if i'm trying to back wheel something and I don't quite make it i'll slip down and hit the bashguard.Hows that going to wreck the frame at-all?If I didn't have it, I would be hitting the frame every time.pics??I'll try get some soon. Edited March 31, 2009 by hdmackay Quote Link to comment Share on other sites More sharing options...
Sam Ward Posted March 31, 2009 Report Share Posted March 31, 2009 Hows that going to wreck the frame at-all?i have no idea?? your the one telling us you'll destroy your frame without it, were only trying to help Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 31, 2009 Author Report Share Posted March 31, 2009 i have no idea?? your the one telling us you'll destroy your frame without it, were only trying to helpOnly because i'll be slipping onto it if I don't make something...you'll destroy your frame even if you have got a bash on thereWhat were you meaning by that then? were only trying to helpI know, i'm not trying to start an argument or anything.I appreciate the help. Quote Link to comment Share on other sites More sharing options...
Sam Ward Posted March 31, 2009 Report Share Posted March 31, 2009 What were you meaning by that then? its a gaurd, its there for emergencies and not designed for regular harsh use and you should never rely on itso like i said if your slipping onto stuff that often your going too big, work on being smoother Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 31, 2009 Author Report Share Posted March 31, 2009 It's a guard, it's there for emergencies and not designed for regular harsh use and you should never rely on it.So like I said if your slipping onto stuff that often your going too big, work on being smoother.Oright. Cool.That's alot clearer now. Quote Link to comment Share on other sites More sharing options...
Hendrix Posted March 31, 2009 Report Share Posted March 31, 2009 Oright. Cool.That's alot clearer now.I can't have a bash plate on mine - I've just had to learn to be more careful. At the end of the day though, you CAN replace a frame. Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted March 31, 2009 Report Share Posted March 31, 2009 Oh right, Cool.That's a lot clearer now.Don't try to be a smart arse when you clearly aren't. Quote Link to comment Share on other sites More sharing options...
Tutzz. Posted April 1, 2009 Report Share Posted April 1, 2009 Hi , This has happened to me before on my t-pro what i did is drilled it out(the stuck bolt) after i did that , i then re-tapped the hole where the bolt goes to fit s different bolt , after i did that i had no problems with it.Hope i helped Rob. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted April 1, 2009 Report Share Posted April 1, 2009 Or you could just take off the bash completely and just use your bashring Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted April 1, 2009 Report Share Posted April 1, 2009 Screw extractors will get the broken stud out;Then either drill the hole bigger and tap it for a bigger bolt, or get it Heli-Coiled.As it's been said, bashing things isn't really the style these days. You'll save weight without the guard anyway Quote Link to comment Share on other sites More sharing options...
