Pads
Luke_zoo
I know Phat pads are the best out at the moment....
But my brake is splipping bad....
And I run
Plazz yellows on the frunt.
And
Rock blues on the back
I have some Echo white pads but they are nerly dead from riding
Are Toxsin pads anygood ?
What would you recomend on the rear ?
Help please :)
Luke
Edited by :)zoo!
Are you running a grind on the rear? If so stick a fresh one one, make sure the rock blues are setup square and you should have an awsome brake! (save some money too!)
Adam
Canot grind rim anymore due to a split rim and its cracked/snaped open on the joint but still running :lol: has not snaped yet :unsure::-:o
How badly is it split, and where? pics? I bet it would be ok with another grind :P
Are the rock blues for a harsh grind? If so get the greens man (Y)
They don't need an overly harsh grind, I tend to runa light sharp grind and they are beasts!
Adam
