Ever Bought Something For You Bike And Found It Shit?
Matt Vandart
I got a Brisa frame which I have wanted for years only to find it's shit :giggle:
I don't know if it's because frames are so much better now than when I first wanted one or what, but it's shit (Or not suited to me anyway.
So I was wondering if anyone had amusing tales of buying something after wanting to get it for ages only to find it's shit.
Matt
I once bought a T-Pro, it cracked in 6 weeks.
I got a second hand front Hope Mono Trial off here, it needed a rotor and a bleed aparantly. Bollocks! It needed a rotor, seal kit, lever reach adjuster, pads and bleed. Cost me an extra £30ish to get it sorted!
Plenty of shit off this forum. Though allot of items have been really good. Won't mention any names... As for new stuff, i've not had too much trouble. The stuff that i have bought which broke quick i got warrantied. The so-so items that i bought i managed to get a happy use out of them then shifted on for a reasonable price.
But i do currently have a Bionic frame that i paid full wack for, never got on with it too well. But i'm going to build it back up shortly and run a different stem, hopefully it will ride better than before.
Hope XC rear hub from 2002 - used it from new on my XC bike for XC - when I went to change the cassette I discovered 6 of the 8 sprockets on my cassette had dug into the steel freehub spline so deeply the cassette had to be hammered off. Contacted Hope and they claimed (Rightly given it couldn't take XC use either) the hub wasn't designed for trials and offered me no support... The freehub bearings would also partially seize when I closed the QR thanks to the spacer between the bearings deforming over time too, so it couldn't be backpedaled, which meant technical climbs were impossible. In a word: Junk. The front hub is still running perfectly years later, but it's hard to screw up two bearings on an axle (Though based on the number of hub flange failures I've seen and heard about from Hope even this isn't guaranteed)...
Shimano XTR 2008 rear hub - I was hoping it'd match the previous XTR hub, which gave me 6 years and thousands of miles of XC use with no servicing required at all (Bearings were still smooth when I opened it to replace the freehub body after some intermittent skipping - It's still running on my XC bike now over 7 years on). Axle on the new model fatigue cracked in under a year, bought on ebay, so no warranty :(...
Formula ORO K18 - leaked through the caliper piston seals within 2 weeks of fitting it brand new to my trials bike.
Best items I've ever bought -
Any Magura brake that wasn't very second hand by the time I got it - The set of HS33's I bought new in 2000 is still running (Used for trials since new).
Any Shimano brake, especially the first XT VBrakes and 4 pot XT disks (Mine are still running 7 years on having eaten countless pads and had the oil level topped up about twice), I replaced the front disk this year - it was 0.5mm thinner than a new disk, so getting a bit dangerous...
DMR V8 pedals - I've yet to have to do more than shove clean grease in through the greaseport every year or two on any I've bought. Sold on one set with at least 3500 miles - often in wet muddy conditions - on them and all they had was a bit of bearing play (Which can be adjusted out anyway). Just fill them with grease before fitting and they seem to run forever.
Shimano XTR dual control levers - Flawless performance, unmatched ergonomics - they're still running as good as new after 1.5 years...
ENO freewheel - beautifully made, almost indestructible and still 100% reliable after well over a year's trials riding so far on it.
my 07 zoo forks lasted 3 days before a dirty great crack appeared haha.
gt hadley hub, 32 ex, went through a few of those, cheap, but tacky
skf bbs, the lockrings keep snapping, even with faced frames :S
avid ad3 lever JUST LOL
hansventure tyre, what a load of wank that thing was
surly tension seeker, oh dearrrrrrr hence the rohloff
