Ram Help :s
Alex Dark
It's always best to keep them in pairs, but for the amount Ram costs these days, may aswell get 4gb.
You'll need to know the maximum MHZ rating your motherboard can run though, I'm pretty sure you can run ram with too high a rating, but not too low....
Krisboats is the guy to ask though, he knows all about Ram and it's magical properties. :P
anyone else?
You'd be better off with 2x1gb than 1x2gb and 1x512mb. As Muel said, it's best to keep them in matched pairs. Which is also why you should try to get the extra cash together for 2x2gb if you can, because you'll only have to do it some other day anyway!
i would have thought id just have a bottleneck then....i mean i doubt my processor will keep up with the 4gb of ram, and ill probably ditch the whole setup before i really need 4gb?
To be honest, I haven't looked into the specific specs of the laptop you have, but you're probably right there. If you're confident that you wont need 4gb any time soon (i.e. you don't do any mega editing of video or photos or run hench games) then go for the 2gb - it's still a huge jump from where you are right now!
yeh thats what i thought...its kind of bearable now, but certainly not amazing
Thanks everyone (Y)
Well there is no point running 4gb until you get 64bit windows (as has already been said). Windows 32bit will only recognise it as 3.25(I seem to remember, its been a while since I had 32bit). So I'd stick to 2x1gb sticks, just make sure you get the fastest speed possible.
Or get 64bit windows and go the whole hog of 4gb, you WILL notice the difference, especially if your using vista...
It doesn't quite work like that. The 4gb of ram won't run any faster than 2gb... that's a complete misconception. The RAM acts to allow the processor to have a greater bandwidth of data. Basically the information goes from your hard drive, to your ram then it gets fed to your processor. Getting faster RAM will give you a potential for a speed based bottleneck, but you'd need a god awful processor with really good RAM. Cleverly they stopped this possibility by introducing ddr2 and more recently ddr3, meaning your processor can be bottom of the range but it will not be holding anything else back too much.
Having more RAM allows larger programs to run from the system memory which means you'll see an increase in system speed when using things like computer games and massive images in photoshop. The files can be fully loaded into the RAM ready for the processor to use without having to page information to your hard drive (hard drives are the slowest part of a computer system). If you've been fine with 512mb for all this time though i'd be inclined to say that 2gb of RAM will be plenty. I have 6gb myself and even with some heavily intensive applications going i'll still only use 2-3gb for 80% of the time i'm on the computer.
Your choice of going for 5300 RAM though puzzles me slightly. I mean, your processor is supposed to be a celeron dual core yes? In which case it'll be good for RAM that's nice and fast to go with it. Unless your motherboard is specifically tied to a maximum speed of pc2-5300 then i'd go for some pc2-6400 or even pc2-8500 stuff to be honest. The cost increase isn't too much because RAM is cheap as anything these days, where as buying the slower stuff is just limiting yourself unnecessarily. The decent brand pc2-6400 stuff i've seen is usually cheaper than the slower stuff to be honest due to current popularity and competing manufacturers. The pc2-8500 stuff is just fractionally more and 2gb of that would set you back around £30.
Download this and run it. It'll tell you the make and model of your motherboard (mainboard) and from there we can look at its maximum speed.
windows xp is in 64x, it can use upto 128gb of ram :P
It does yes, but if he's only got 512mb of ram there's no way he's running a 64 bit operating system as well.
