Build A Bike.
neonneon
Hello,
I got really bored, so I thought i'd build a bike.
then I finished that and got bored again, so I thought i'd make a topic about it.
Just build a bike on whatever site you like and paste your shopping cart.
Onza Ice - £282.85
Echo Lite '07: Silver, 4-Bolt/Disc - £68.51
Trialtech/Echo/Try-All Fixed 19" Rear - £155.62
Trialtech/Echo/Try-All Disc 20" Front - £132.13
Try-All ISIS: 127.5mm Axle - £50.89
Echo Sealed Bearing - £63.62
Trialtech Sport Forged: 175mm ISIS, Black - £48.94
Magura HS33 White (Pair): 4-Bolt Mounts - £122.34
Try-All Croco: Yellow - £17.62
Gusset Tank Chain, 3/16 - £9.79
Trialtech Sport Riser Bar: Silver - £47.96
Trialtech Sport Forged: White - £34.26
Trialtech Carbon (booster) - £38.17
FSA Pig: Silver - £16.64
Trialtech Sport Magnesium: White (pedals) - £44.04
I think i got everything :giggle:
Charlie
Edited by neonneon
Chris king No thread head set -£116.47
Viz forged Stem 20" -£38.17
Try-all rage bar -£60.68
Chris king ISO front -£126.26
Chris king bmx rear -£361.15
Echo Sl rear -£48.94
Echo Sl front -£44.04
Trial-tech spokes x2 -£29.36
Gu typhoon 08 -£292.04
Zoo python forks disk only -£73.41
Tensile crank arms -£96.89
Reset titanuim -£96.89
Trial-tech K810 kool - £13.70
Gusset b*****d grips -£6.85
Hope mono front disk -£176.16
Echo tr rear rim brake -£78.30
Tensile offset brake mounts -£19.57
Echo urban 4bolt brake booster-£29.36
Tryall carbon effect rim tape x2-£7.82
Monty 20/19" tube x2 -£9.78
Tryall stiky rear -£34.26
Tryall stiky front -£29.36
Sub-total: £1809.64
Postage & Packaging: £10.00
VAT: £237.34
Total: £1819.64
Due to the weight constraints of your order, or the shipping region that you have selected, we are unable to provide you with an automatic delivery quote. However, if you click on the continue button below, we will email you a delivery quote which will then allow you to pay for your order.
Sub-total: £1809.64
Sub-total: £1809.64
VAT: £237.34
Total: £1819.64
Sub-total: £1809.64
Haha, Thats ridiculous :P
I tried to make mine reasonable :) Mine only came to £1100
My Dream bike... 8.2KG's as standard... not bad :P
Koxx Hydroxx2 1.744kg £556
Echo SL 20" Forks 588g £78
Reset Titanium BB 179g £96
Monty ISIS Crank Bolts 20g £8
Avid Ultimate 182g £92
Avid Ultimate Lever 76g £73
Onza 4bm-canti 70g £19
Clark's Brake Cable 50g* £3
Try-All ISIS 420g £88
Onza Pro Series Rear 435g £73
Trialtech Square Front 394g £38
Try-All 'H' 116 Disc r 172g £102
Try-All Sealed f 80g £83
Mutiny Plain Gauge 100g* £9
Trialtech Lite Z610 HX 330g £11
Try-All 108.9 179g £53
Monty Eagle Claw 19" 998g £26
Monty Eagle Claw 20" 580g £17
Try-All Ti-Nesium 300g £145
Maxxis Ultralight 102g £7
Try-All Carbon Riser 211g £136
Monty 221 Kamel stem 199g £79
Echo SL Headset 95g £39
Try-All Carbon rimtape 28g £4
Onza V-Daptor 36g £8
French ID Foam 12g £6
Total 8224g £2064
26innch ......
frame=GU Typhoon '08 £292.64
forks= Trialtech Sport 26" £116.47
headset=Echo 7075 Headset £44.04
stem=Trialtech Sport Forged white £34.26
handlebars=Trialtech Sport Riser Bar white £47.96
front brake=Avid BB7 '08 203mm £53.83
front brake lever=Avid SD7 Lever £10.77
brake cable=Clark's Brake Cable £3.91
front wheel=Echo TR Front 26 £77.32
front tyre=Maxxis Larsen TT £19.57
rear brake=Echo TR Rim Brake black £78.30
brake clamps=Echo CNC Brake Clamps black £23.49
brake lever=Echo CNC Lever Blade '08 £19.58
bottom bracket=Echo TR ISIS £48.94
cranks=Try-All ISIS black £88.09
rock ring=GU Bashring black £19.57
freewheel=Try-All 108.9 £53.83
pedals=Trialtech Race black £19.57
chain=KHE Collapse, 1/8" £17.62
rear wheel=Echo TR Rear 26 £96.89
sprocket=Trialtech Sport Screw On 15tooth £14.68
rear tyre=Continental Der Kaiser 2.5" £44.04
iner tubes=x2 Maxxis Welterweight (Unboxed) 26''£7.82
chain tensiorner=74Kingz SingleSpeed £31.32
rim tape=x2 Try-All 25mm Wide black £5.88
total=£1270.33
Mod :
Your basket is currently empty
GU Typhoon '08
@ £292.64
Echo 7075 Headset: Blue
@ £44.04
Echo Lite '07: Silver, Disc Only
@ £68.51
Echo Team
@ £34.26
Echo Urban Flat: Blue
@ £29.36
Hope Tarty Trial: Front, Right Hand, 200mm (with +20 adaptor)
@ £161.49
Magura HS33 (Single): Black, Left Hand, 4-Bolt
@ £63.62
Echo 6061 Forged: 160mm ISIS
@ £50.89
Echo TR ISIS
@ £48.94
Tensile Freewheel
@ £34.26
Echo TR Front 20"
@ £77.32
Echo TR Rear 19"
@ £96.89
Maxxis Creepy Crawler Rear 19''
@ £17.62
Maxxis Creepy Crawler Front 20''
@ £15.65
Gusset Slim Jim Alloy: White
@ £29.36
Total: £1074.85
  • 5 weeks later...
BUMP :P here we go!
Fame:GU Typhoon 08 £292.64
Wheels:BACK:Try-all hole rear 19" £53.83, Echo free hub (black) £56.27. FRONT: Try-all hole front 20" £44.04, Try-All hub £83.19.
Brakes: BACK: Magura HS33 (black) £122.34, Try-all Croco pads £17.62. FRONT: Magura HS33 (black) £122.34, Rock Pads £17.62.
Forks: Trialtech Sport £116.47.
Stem & Bars: Monty 221 Kamel stem £72.43, Monty 221 Ti Riser £53.83
Cranks Freewheel etc: Czar CNC Cranks £88.08, Rockman freewheel £38.17, 74Kingz Bashring £34.26.
Other: KMC Chain £11.74, Trialtech Carbon Booster £38.17, Try-all stiky tyre rear 19", Monty Eagle Claw 20'' £17.62, V!Z Magnesium pedals £48.94.
All together: (get ready) £1329.6!!!!!!!!!!!!!
Koxx White Sky
@ £782.00
White Industries ENO Trials
@ £84.00
Sunline Logo: Black, Thick
@ £12.71
@ £136.04
Chris King NoThreadSet: Black
@ £116.47
Chris King ISO Front: Black,32h
@ £126.26
Chris King BMX Rear: Black, 36h
@ £361.15
Try-All Ti-Nesium
@ £145.83
Onza Pro Series Rear 19''
@ £73.40
Try-All hOle Front 20'': Black
@ £44.04
Trialtech Plain Gauge 19/20" (White) with Nipples: Specify Hub/Rim/Hole
@ £29.36
Chris King Kog: 12T
@ £34.26
Chris King Kog: 18T
@ £34.26
Monty 221 Kamel (with Top Cap): 165mm x 30°
@ £79.28
Monty 221 Kamel
@ £194.77
Kenda 19'' DH
@ £7.34
Maxxis Ultralight
@ £7.33
Try-All Stiky Rear 19'': White
@ £34.26
Try-All Stiky Front 20'': White
@ £29.36
TartyBikes Headset Fitting
@ £2.94
TartyBikes Rim Grind: Non-Echo, Medium
@ £2.94
Try-All Disc Brake: Front, Right Hand, 155mm
@ £185.96
Try-All Disc Brake: Rear, Left Hand, 155mm
@ £185.96
TartyBikes BB Fitting
@ £2.94
SKF BFR-600: 128mm
@ £58.72
74Kingz 4-Bolt
@ £41.11
Monty Eagle Claw Bashplate with Bolts
@ £56.77
Koxx XTP Bashplate Rubber
@ £4.89
Delivery: £10.00
Total: £2884.35
Some of the bits I didnt need but oh well :P
perfect semi budget bike
ECHO 07 FRAME 243.70
ONZA MUSCLEMAN CRANK 47.96
MIDDLEBURN INNER CHAINRING 12.72
MAGURA HS33 BLACK PAIR 4 FINGER 127.23
MONTY 211 PR FORKS 58.72
MONTY 219 REAR WHEEL 44.04
MONTY 219 FRONT WHEEL 44.04
VIZ SEVENTY TWO FREE WHEEL 39.15
MAXXIS CREEPY CRAWLER FRONT + REAR 33.27
VIZ SQUARE TAPER BOTTOM BRACKET 17.13
TMS WELDED STEM 29.36
META TCS HEADSET 28.38
MONTY 219 RISER BARS 23.49
GUSSET SLIM JIM ALLOY PEDALS 29.36
TRIALTECH K810 KOOL CHAIN 13.70
ONZA CHAIN TUGS 7.83
TRYALL LOCKALL GRIPS ANGEL WHITE 14.19
MONTY TUBES 1X19 1X20 9.78
______
824.05
Echo Team '07
£243.70
Echo Lite '07 (silver maggie mounts)
£68.51
Echo SL Headset (gold)
£39.15
Echo Team stem
£34.26
£47.96
Echo SL CNC Cranks (silver)
£107.66
Wellgo Magnesium Pedals
£44.04
Echo Urban Bashring
£24.47
KHE Collapse, 1/8"
£17.62
Trialtech Foam £5.87 or Echo Rubber £6.36
Magura HS33 Silver (with fluro yellow pistons) front and rear
£63.62
Echo TR Brake Clamps (gold)
£24.47
Echo HS33 '07 (front)
£17.62
Heatsink coust (rear)
£32
Chris King BMX Rear (black)
£361.15
Echo Non-Disc Front '08 (black)
£39.15
Echo SL Rear 19'' (gold)
£48.94
Echo SL Front 20'' (gold)
£44.04
Mutiny Plain Gauge 19/20" (Black) with Nipples
£9.79
TartyBikes Wheelbuild (All parts bought from them) X2
£9.79
Cheng Shin 19/20''
£4.89
Kenda 19'' DH
£7.34
Echo Rear 19''
£19.57
£15.65
All adds up to £1341.54
Hmm i think thats everything. Tell me if im missing anything :P
Ginge Allen
Edited by ginger allen echo
Echo Lite Bashplate with Bolts & Rubber: Silver
@ £19.57
Trialtech Titanium Halfring
@ £33.28
Try-All ISIS: 122.5mm Axle
@ £50.89
Try-All CNC Brake Clamps
@ £29.36
Hope Mono Trial Carbon/Ti: Front, Left Hand, 180mm
@ £176.17
Magura HS33 White with 4-Bolt Mounts & Olive: Single, Right Hand, 2-Finger
@ £63.62
Trialtech K810 Kool, 3/32''
@ £13.70
Echo SL Alloy Crank Bolts: Silver
@ £11.74
Trialtech Sport Forged: 175mm ISIS, Silver
@ £48.94
Trialtech Sport 20'': Disc Only
@ £116.47
Onza Ice
@ £282.85
TartyBikes Chainstay Protector
@ £5.87
Tensile Freewheel
@ £38.17
Trialtech Foam
@ £5.87
Echo SL Bar End Plugs: Silver
@ £14.68
Trialtech Sport Riser Bar: white
@ £47.96
Hope Headset 07: Silver
@ £58.72
Hope Pro 2: Silver, 32h
@ £48.94
Trialtech Sport Rear Hub: White
@ £44.04
@ £44.04
Hope CNC Steel Skewer '09 (Single): Front, Silver
@ £14.68
Trialtech Rim Tape: White, Front, 20"
@ £2.94
Trialtech Rim Tape: White, Rear, 19"
@ £2.94
Trialtech Sport Rear 19'': SL Grey
@ £38.17
Trialtech Square-Holed Front 20'': SL Grey
@ £38.17
@ £14.68
Trialtech Sport Screw On: 12T
@ £11.74
Trialtech Sport Forged stem: White
@ £34.26
Monty 19/20'': 19" (unboxed)
@ £4.89
Maxxis Ultralight
@ £7.33
Try-All Stiky Rear 19'': Black
@ £31.32
Try-All Stiky Front 20'': Black
@ £21.53
Trialtech grip stops
@ 5.87
Update Basket
Delivery: £10.00
Total: £1393.40
That is deffantly my dream bike but I would change the colours of some stuff, like silver Trialtech forks(if only they made them...) Oh year, and ti bolts throughout. :P
