Jack Chinnery Posted March 17, 2009 Report Share Posted March 17, 2009 Ive searched it and nothing came up. My spokes on my 07 onza (shitty) wheel are creaking. Its one of the cheap onza wheels which come with the standard bike. Im not sure what it is, Ross G said to loosen the spokes 1/4 of a turn, I did and yet it still creaks and also it is a factory build so nothing done to it apart from the loosening. I think its the threads fooooked in the nipples, what do you think?Cheers guys. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted March 17, 2009 Report Share Posted March 17, 2009 Ive searched it and nothing came up. My spokes on my 07 onza (shitty) wheel are creaking. Its one of the cheap onza wheels which come with the standard bike. Im not sure what it is, Ross G said to loosen the spokes 1/4 of a turn, I did and yet it still creaks and also it is a factory build so nothing done to it apart from the loosening. I think its the threads fooooked in the nipples, what do you think?Cheers guys. are you sure it's the spokes are you sure it might not just be you're crank creaking due to you're crank arm's being slightly lose try tighting them up and if not try tighting you're spokes ever so slightly but do them all equally so that you dont make you're rear wheel slightly buckled Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 17, 2009 Author Report Share Posted March 17, 2009 are you sure it's the spokes are you sure it might not just be you're crank creaking due to you're crank arm's being slightly lose try tighting them up and if not try tighting you're spokes ever so slightly but do them all equally so that you dont make you're rear wheel slightly buckledSounds quite like a crack doing that. Ill give it a check over in a while. It sound even louder and worse when I lean over the bars, But the sound only occours when motional.? Quote Link to comment Share on other sites More sharing options...
Jordan GU Posted March 17, 2009 Report Share Posted March 17, 2009 My dmr was making a funny creaking noise it was the spokes on front wheel....I couldn't be botherd to sort it. Then it just stopped Sorry i wasn't any help. Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 17, 2009 Author Report Share Posted March 17, 2009 My dmr was making a funny creaking noise it was the spokes on front wheel....I couldn't be botherd to sort it. Then it just stopped Sorry i wasn't any help.Jordan, You know what im like. You dont need to say something like that. Quote Link to comment Share on other sites More sharing options...
eskimo Posted March 17, 2009 Report Share Posted March 17, 2009 Lack of spoke tension is more likely to cause creaking than too much tension. Quote Link to comment Share on other sites More sharing options...
Sidehop Stuart Posted March 17, 2009 Report Share Posted March 17, 2009 HAHA JACK!Mine does that too! on my invisible trials bike. Just check it out thoroughly is my only advice. Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 17, 2009 Author Report Share Posted March 17, 2009 HAHA JACK!Mine does that too! on my invisible trials bike. Just check it out thoroughly is my only advice. Cheerz my dearzzzzzz, So you getting a Shogan gimp them? Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted March 17, 2009 Report Share Posted March 17, 2009 loose spokes mine did it the other day. Quote Link to comment Share on other sites More sharing options...
Jitters Posted March 17, 2009 Report Share Posted March 17, 2009 If you're sure it's the spokes then loose spokes can be the problem, as suggested - OR - the spoke nipples aren't turning freely when you tighten them. The spokes can actually wind up and will make funny creaking or pinging noises as you ride around. If it's the latter case, that will eventually go away as the spokes work themselves back into form. A bit of oil where the nipple runs through the rim and at the threads before tightening can help with this if this is the case. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 17, 2009 Report Share Posted March 17, 2009 take the wheel off and de-stress it...lean it ont he floor and push downwards on either side, should ping. That might sort it. Quote Link to comment Share on other sites More sharing options...
chrisbikefix Posted March 17, 2009 Report Share Posted March 17, 2009 alot of wheels do that, it sounds to me there not tight enough. Its just where the spokes cross over each other. I would get a shop to tighten them and like some other chap said, de-strees it by pushing on the wheel. Then maybe if nothing else works just put a small piece of paper where the spokes cross .... haha Quote Link to comment Share on other sites More sharing options...
