hdmackay Posted March 16, 2009 Report Share Posted March 16, 2009 Hey guys.The other day I decided to bleed my brake with water just after I had come in from riding. I had just been out so there waws obviously no leaks or cracks.Once the brake was off, I tried bleeding it. It didn't work the first few times (My first ever attempt at a bleed) and then when it seemed alright, I noticed that once I had been pulling the lever a bit more air was appearing in the system. So I checked it and saw a crack in the lever. The crack is right above where the bleed screw goes in and the water leaks out of it.I was wasn't sure how it cracked because I don't remember dropping it or anything so I am wondering... Is it possible for a lever to crack from overtightening the bleed bolt?!That's the only explanation I can think of... Unless I hit it of something.Cheers in advance guys. Quote Link to comment Share on other sites More sharing options...
Andrew Willis Posted March 16, 2009 Report Share Posted March 16, 2009 Hey guys.The other day I decided to bleed my brake with water just after I had come in from riding. I had just been out so there waws obviously no leaks or cracks.Once the brake was off, I tried bleeding it. It didn't work the first few times (My first ever attempt at a bleed) and then when it seemed alright, I noticed that once I had been pulling the lever a bit more air was appearing in the system. So I checked it and saw a crack in the lever. The crack is right above where the bleed screw goes in and the water leaks out of it.I was wasn't sure how it cracked because I don't remember dropping it or anything so I am wondering... Is it possible for a lever to crack from overtightening the bleed bolt?!That's the only explanation I can think of... Unless I hit it of something.Cheers in advance guys.it must be that youve dropped it mate. im sure that it would have stripped the threads if the bolt was over tightend Quote Link to comment Share on other sites More sharing options...
RossMcd Posted March 16, 2009 Report Share Posted March 16, 2009 (edited) Is it possible for a lever to crack from overtightening the bleed bolt?!Answered the question yourself there Magura levers crack before they strip Edited March 16, 2009 by RossMcd Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 16, 2009 Author Report Share Posted March 16, 2009 Answered the question yourself there Magura levers crack before they stripf**k, so how hard are you meant to tighten it?!Because I thought bleed bolts were meant to be tight.... Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 16, 2009 Report Share Posted March 16, 2009 ive craked one doing that...was butted...only seems to be the old 04's though Quote Link to comment Share on other sites More sharing options...
bigamac Posted March 16, 2009 Report Share Posted March 16, 2009 f**k, so how hard are you meant to tighten it?!Because I thought bleed bolts were meant to be tight....Just do it till its tight not ultra-tight lool. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted March 16, 2009 Report Share Posted March 16, 2009 ive craked one doing that...was butted...only seems to be the old 04's thoughHunters brakes are the 05 version. I have seen it happen on the 05 models before! Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 16, 2009 Author Report Share Posted March 16, 2009 Yeah, next time, I'll probably end up doing it too slack and it will leak.... Quote Link to comment Share on other sites More sharing options...
bigamac Posted March 16, 2009 Report Share Posted March 16, 2009 Yeah, next time, I'll probably end up doing it too slack and it will leak.... Just do it till its tight not ultra-tight lool. Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 16, 2009 Author Report Share Posted March 16, 2009 Sound, Can the same thing happen at:1) The Piston?2) The bit on the lever where the hose is connected to3) The bit on the lever that clamps onto the barsCan any of these bits crack from overtightening? Quote Link to comment Share on other sites More sharing options...
RossMcd Posted March 16, 2009 Report Share Posted March 16, 2009 Sound, Can the same thing happen at:1) The Piston?2) The bit on the lever where the hose is connected to3) The bit on the lever that clamps onto the barsCan any of these bits crack from overtightening?The two in bold can indeed! never tighten the lever clamp too tight. I done it once and it snapped. held it on with electrical for temps. I have never seen a hose line shroud nut snap a lever but it could be possible. Quote Link to comment Share on other sites More sharing options...
hdmackay Posted March 16, 2009 Author Report Share Posted March 16, 2009 Oright.Cheers. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted March 16, 2009 Report Share Posted March 16, 2009 The two in bold can indeed! never tighten the lever clamp too tight. I done it once and it snapped. held it on with electrical for temps.Same thing happened to my birds lever, the design is utter wank.Matt Quote Link to comment Share on other sites More sharing options...
Simpson Posted March 17, 2009 Report Share Posted March 17, 2009 My decided to snap in 3 places yesterday... can get pics if needed Quote Link to comment Share on other sites More sharing options...
