Rear Brake?
Nick Manning
As mentioned in my other topic, I'm having problems with my rear magura. Unfortunately I have no choice but to use the Tensile offset mounts, as I love using cnc backing pads, and they wont fit if I use standard mounts. So, as a solution I want to change my magura for something different.
I'm in a toss up between going for a rear disc or a rear v. I'm more inclined for a rear disc as I do the local comps, and at times it can be very messy, and so a disc would be benficial.
My question is:
Which brake would be better, a disc or a v-brake?
If a disc, then which would be better? or if a v-brake, then what would be the best set up?
Any advice would be much appreciated, thanks.
Edited by Nick Manning
Im running a Echo front double wall rim on the rear, I can run standard mounts with the magura, but then can only run plastic backings. Using the tensile mounts allows me to run the cnc backings which in my opinon feels so much nicer than plastic backings.
Is it heatsink backings you are running, one option would be to get some Phat backings, they are alot lower profile than heatsink ones (about the same as plastic backings)
Adam
The frame is narrow compared to most frames, but the bikes as standard come with a dx 32 rim with a magura hs33 and std 4 bolt mounts. If I stick with that rim I have no problem and the frame is fine, but as I want to run cnc backings and a white rim, I have had to go for the echo front to be able to run the cnc backings.
