Nick Manning Posted March 16, 2009 Report Share Posted March 16, 2009 I've been having problems with my Tensile offset mounts, just wandering if anyone else has had any problems with them?The problem I a having, is that when I tighten the clamp bolts up, the two mounts end up touching. This as I know shouldn't be a problem, but when I'm riding my brake cylinder will slowly move and start angling its way up. My brake pad will be set up so the pad hits the rim, when the brake cylinder moves the pad is then hitting the tyre.This is getting frustrating as I can't understand why it would this. I bought a brnad new set of Tensile mounts but they still do it, so I'm stumped.Anyone got any clues? Quote Link to comment Share on other sites More sharing options...
walker Posted March 16, 2009 Report Share Posted March 16, 2009 Seems strange, are they put together correctly ie. not using two bottom ones and two top ones together (although i dont think you'd do something like that ). is the plastic clip thing inside ok? Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted March 16, 2009 Author Report Share Posted March 16, 2009 Everything is being used correctly, both mounts have 1 top and 1 bottom and have the two plastic clips in. I was thinking about trying to pack it out a tiny bit, so that the bolts could tighten a bit more, but even if that worked it's not something that should need to be done. Quote Link to comment Share on other sites More sharing options...
Bigman Posted March 16, 2009 Report Share Posted March 16, 2009 I am not sure what the tensile mounts are like, but i had the same problem with my CNC echo clamps, what i ended up doing was filing the little tabs off so that they would clamp together further, if the tensile clamps do not have little tabs i would possibly suggest filing say 1mm off either the lower or upper mount so that they can clamp together better.Just another option.....Adam Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted March 16, 2009 Author Report Share Posted March 16, 2009 Hey Adam, they do have tabs, not very deep one's, bout 1/2mm. I'l give that ago. But that is all I need is to just be able to get the bolts to tighten just that bit more.Cheers Adam Quote Link to comment Share on other sites More sharing options...
sstein Posted March 16, 2009 Report Share Posted March 16, 2009 I had the same problem when I used them. The problem is that they are stiffer than normal maggy mounts, so even though the tab is the same as the maggy one it takes more force to fully clamp it, the problem with this is that this extra force will strip your threads.You can file the tabs a bit, but what I found works amazingly is putting another strip of plastic under the normal adjustment ring. I did this and have not had any problems since. Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted March 16, 2009 Author Report Share Posted March 16, 2009 I had the same problem when I used them. The problem is that they are stiffer than normal maggy mounts, so even though the tab is the same as the maggy one it takes more force to fully clamp it, the problem with this is that this extra force will strip your threads.You can file the tabs a bit, but what I found works amazingly is putting another strip of plastic under the normal adjustment ring. I did this and have not had any problems since.Thats what i was thinking, however my bolts wont go any tighter and the mounts are touching, so the only way to get them to tighten more would be to put a strip under the plastic ring. Though I'm going to get a set of Phatworks cnc backings which should allow me to use standard magura mounts, so hopefully my problem therefore cease. Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted March 16, 2009 Report Share Posted March 16, 2009 Nick, I had the same problem with the two pairs I had.I had to file the tabs down a bit. Make sure if you do this to file it as square as possible, other wise the pad will sit squint.The tensile mounts are a great idea, just not very well thought out. Quote Link to comment Share on other sites More sharing options...
psycholist Posted March 16, 2009 Report Share Posted March 16, 2009 Thats what i was thinking, however my bolts wont go any tighter and the mounts are touching, so the only way to get them to tighten more would be to put a strip under the plastic ring.This is probably a long shot but check that the brake bolts aren't bottoming in the brake mount hole. If they're hitting the bottom of the hole the bolt will feel tight, but won't put decent clamping force on the brake. Quote Link to comment Share on other sites More sharing options...
sstein Posted March 16, 2009 Report Share Posted March 16, 2009 You don't want them tighter as you will strip the threads, that is why I said to use the extra bit of plastic, however filing it down doesn't sound like tooo bad an idea, just clamp it in a vice, put a file flat over both sides and it will file evenly and flat! Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted March 16, 2009 Author Report Share Posted March 16, 2009 Thanks for all the advice guy's. Im gonna be using the phat works backings now, so hopefully wont need to use the tensile mounts. If I do then I'l file those tabs down and see how it works.CheersEveryone Quote Link to comment Share on other sites More sharing options...
Rob Brodie Posted March 16, 2009 Report Share Posted March 16, 2009 Thanks for all the advice guy's. Im gonna be using the phat works backings now, so hopefully wont need to use the tensile mounts. If I do then I'l file those tabs down and see how it works.CheersEveryoneWorks a treat nick Quote Link to comment Share on other sites More sharing options...
weirdoku Posted March 16, 2009 Report Share Posted March 16, 2009 My Zhi mounts has that problem, I wrapped a few layers of insulation tape round the cylinders, beneath the washers and it's all good! Quote Link to comment Share on other sites More sharing options...
