elliott the onza man Posted March 14, 2009 Report Share Posted March 14, 2009 Will my T-pro headset fit in the my new Adamant A3 frame or not, I need help.Is there anything else that will not fit, everything is standard apart from handlebars and stem and my brakes which I know will fit.Thanks a lot. Elliott Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted March 14, 2009 Report Share Posted March 14, 2009 Yes, Elliot, yes it will.Matt Quote Link to comment Share on other sites More sharing options...
Table-Salt Posted March 14, 2009 Report Share Posted March 14, 2009 No it wount! The onza T-pro are internal headsets and the a3 are standard so you will need to get a new headset. Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 14, 2009 Author Report Share Posted March 14, 2009 Will the crank creed headset be fine.Thanks. Quote Link to comment Share on other sites More sharing options...
Mikee Posted March 14, 2009 Report Share Posted March 14, 2009 No it wount! The onza T-pro are internal headsets and the a3 are standard so you will need to get a new headset. He is right! Quote Link to comment Share on other sites More sharing options...
Daniel C Posted March 14, 2009 Report Share Posted March 14, 2009 No it wount! The onza T-pro are internal headsets and the a3 are standard so you will need to get a new headset. He is right!Correct me if im wrong but didnt the old t-pro's have standard headsets?i thought they only had the internal headsets when the noew frame came out 2003 was it? Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 14, 2009 Author Report Share Posted March 14, 2009 Mine was the one before the pro so it has an internal.Will anything else not fit or will it all be fine.Thanks Quote Link to comment Share on other sites More sharing options...
Daniel C Posted March 14, 2009 Report Share Posted March 14, 2009 Mine was the one before the pro so it has an internal.Will anything else not fit or will it all be fine.Thanksin that case then no it wont fit as the a3 headset is external. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted March 14, 2009 Report Share Posted March 14, 2009 Correct me if im wrong but didnt the old t-pro's have standard headsets?i thought they only had the internal headsets when the noew frame came out 2003 was it?they got internal headsets in 2004 i belive Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 14, 2009 Author Report Share Posted March 14, 2009 So will it all fit my Adamant A3 then! Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 14, 2009 Report Share Posted March 14, 2009 http://tartybikes.co.uk/product.php?produc...;category_id=19 Should do you fine. I have one in my DJ bike and ive not had any problems with it. So will it all fit my Adamant A3 then!No.Adamant = ExternalT-poo = Internal.End of. Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 14, 2009 Author Report Share Posted March 14, 2009 Will my rear wheel fit the A3, it is the standard T-pro and I can put snail cams on if nessasary. Thanks Quote Link to comment Share on other sites More sharing options...
Daniel C Posted March 14, 2009 Report Share Posted March 14, 2009 they got internal headsets in 2004 i belivewas that when they brought the new frame deisgn out?cant remember lolWill my rear wheel fit the A3, it is the standard T-pro and I can put snail cams on if nessasary. Thanksyes your rear wheel will fit on a a3.If your still unsure about this give tartys a ring on there technical line and they will help you out Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 14, 2009 Author Report Share Posted March 14, 2009 Thanks for all of your help everyone.Much appreciated.Elliott Quote Link to comment Share on other sites More sharing options...
