elliott the onza man Posted March 14, 2009 Report Share Posted March 14, 2009 wheel my rear standard T-Pro wheel fit on my Adamant A3 frame if i use snail cams?thanksElliott Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted March 14, 2009 Report Share Posted March 14, 2009 yes it should fit fine Quote Link to comment Share on other sites More sharing options...
George.E Posted March 14, 2009 Report Share Posted March 14, 2009 Yes, should fit fine Quote Link to comment Share on other sites More sharing options...
Dave! Posted March 14, 2009 Report Share Posted March 14, 2009 just make sure the axel isnt a tiny bit too long (like a few mm) as mine was when I got a zoo and had to replace it with a slightly shorter one.basically the axel stuck out a few mm and the bolts when tightened didnt touch the frame.....so just be aware.apart from that I can't see why it would'nt fit. Quote Link to comment Share on other sites More sharing options...
Jordan GU Posted March 14, 2009 Report Share Posted March 14, 2009 (edited) . Edited March 14, 2009 by Jordan GU Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 14, 2009 Author Report Share Posted March 14, 2009 It is just because all of my mates hubs are longer so I just wasn't sure, i hope it does fit.thanksElliott Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 14, 2009 Report Share Posted March 14, 2009 yeh should be fine...if it's too long, im sure you can use some kind of washer to shim it out a bit Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 15, 2009 Author Report Share Posted March 15, 2009 Thanks, the bike shop will no what to do.Elliott Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted March 15, 2009 Report Share Posted March 15, 2009 you alright elloit?you got the t-pro with green handlebars?? whe did you get an A3 frame? short or long?? chris Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 15, 2009 Author Report Share Posted March 15, 2009 (edited) Ordered it on Thursday night and I will have it by Monday. I am just hoping everything will fit. Did you change your headset when you got your Czar frame?Yea I am the one with the T-Pro.Elliott Oh yea and it is a short. Edited March 15, 2009 by elliott the onza man Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted March 15, 2009 Report Share Posted March 15, 2009 cool, !yer you need to get and extrenal headset! t-pros/t-coms/t-vees use internal they dnt fit like adamants, czar, etc. the newer frames, the only thing that will be diffrent is the wheel base, means you might have to replace/remove links. shame, im selling my czar frame already with a headset oww and you need s-cams Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 15, 2009 Author Report Share Posted March 15, 2009 Yea Harry's got some cams I can have for £5I'm taking it to Tibbs to get it put together.Thanks. Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted March 15, 2009 Report Share Posted March 15, 2009 Yea Harry's got some cams I can have for £5I'm taking it to Tibbs to get it put together.Thanks.im wanting a t-pro for a change, dont ask why. ive got a ddg headset silver. you fancy swapping for your snail cams and headset ? yer use tibbs there the best! Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 15, 2009 Author Report Share Posted March 15, 2009 No because I need the cams. Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted March 15, 2009 Report Share Posted March 15, 2009 No because I need the cams.what for? Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 15, 2009 Author Report Share Posted March 15, 2009 To put on my Adamant. Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted March 15, 2009 Report Share Posted March 15, 2009 To put on my Adamant.adamants take snail cams Quote Link to comment Share on other sites More sharing options...
elliott the onza man Posted March 15, 2009 Author Report Share Posted March 15, 2009 Yea and your saying you want them. Quote Link to comment Share on other sites More sharing options...
Chris - Burman Posted March 15, 2009 Report Share Posted March 15, 2009 Yea and your saying you want them.no i want the chain tugs which you use on your bike Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 15, 2009 Report Share Posted March 15, 2009 Thanks, the bike shop will no what to do.Elliottthey probably wont.... Quote Link to comment Share on other sites More sharing options...
