Hs33 Problems !
its mark
  James 24/7 trials said:
Hi i bought a Onza Blade a month and a bit ago and ive got the same problem.
I think that they should have good pads to start with!
Can you recomend me some pads please?
Also what does a brake booster actually do?
Thanks james
A brake booster reduces flex in you're frame when you pull the brake in because if you have noticed the brake flexes slightly where the brakes are when you pull in the brake therefore you have a bit of metal as you might say added on to you're frame (Y)
Also i would recomend Heat sink blueberry pads a mate of mine has them and they are really sharp ( bite really well ) also super loud braking sound might be what you like might not be but thats what i recomend
