Base Ta26
mountian goat
hey all just ordered my self a base ta26 always wanted one !
just a few questions though:
1. will a crane creek headset fit in the frame?
2.will a echo square taper bottom braket fit?
3. what gear ratio do you think i should run for street? (using a freehub)
4. what would it run like if i was to use 24" wheels like some guy on here called heatsink did few years back
5. list me a spec you think will be good for street !
1. will a crane creek headset fit in the frame? yep, if its external
2.will a echo square taper bottom braket fit? yep
3. what gear ratio do you think i should run for street? (using a freehub) er, 18-15 i reckon
4. what would it run like if i was to use 24" wheels like some guy on here called heatsink did few years back not very nice, bb would be too low for a 24, would be a pig on the back wheel
er, echo urban forks
pro2 on dx32
old zoo bars / truvativ bars
any 110mm x 15* stem
any lightish front wheel
dual ply rear, single ply front tyres
rear magura on smooth rim, plaz crm pads
front avid bb7 180mm
middleburns / echo forged cranks
any seat
kmc kool chain
74kingz tensioner
Spec wise, any decent rigid trials fork, i'm fond of Pashleys myself :)
90x15 stem, anything longer felt gash on my 3 Bases!
Some 2 inch rise bars, azonic dw are nice feeling, but i have recently taken a liking to kore freerides, mega nice shape and seemingly strong
I ran 3 pieces and middleburns on mine, prefered 3 pieces cos they are stiffer :)
Hope hubs on reasonably slim rims, ideally 32mm and below due to brake clearance
V brake out back for sure, and v/disc up front. Maguras are a shit to set up on evo adaptors, and vs are just better :P
i think for gear ratio im a running a 22 tooth on the front but not to sure for the back. i still want to be able to like forward hop but high enough to get speed for street so what would you say i should run on the back?
lee x
id run a roadie cassette, and a sora rear mech...
use the 18th for trials, 12t for street-street
