londonliam Posted March 9, 2009 Report Share Posted March 9, 2009 (edited) been finkin....like alot of use here were also part of the sister BMX forum.basically i ride bmx and mtb and was wondering if the odessey linear slic cables would work as a gear cable?i was think this because the oddy cables are designed not to compress (like a gear cable)so is there anythink to stop this working?this would open up endless colour options for gear cables and would be predi sweet!anyone ever tried this?or have any views thoughts on it?cheers Edited March 9, 2009 by londonliam Quote Link to comment Share on other sites More sharing options...
fatty r Posted March 9, 2009 Report Share Posted March 9, 2009 im not sure if it woulkd work or not but if you wanted a different coulercable you gould buy the whole thing then take out the brake cable and just use the coulered outer and a normal gear cable inside it . I also think that the litte bit at the end of your cable that joins it to your leaver / or shifter are different sizes. Quote Link to comment Share on other sites More sharing options...
londonliam Posted March 9, 2009 Author Report Share Posted March 9, 2009 its my fault i didt make my self clear.loli agree with you mate,i ment just use the colour'd outters and use normal gear inners Quote Link to comment Share on other sites More sharing options...
fatty r Posted March 9, 2009 Report Share Posted March 9, 2009 ye you should be able to use the coulered outes no problem Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 9, 2009 Report Share Posted March 9, 2009 yeh that'll work fine mate Quote Link to comment Share on other sites More sharing options...
londonliam Posted March 13, 2009 Author Report Share Posted March 13, 2009 cheers for all the feed back Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 13, 2009 Report Share Posted March 13, 2009 I just used a gear inner in an outer brake on a customer's at work and it felt fine. Quote Link to comment Share on other sites More sharing options...
