onza boy27 Posted March 5, 2009 Report Share Posted March 5, 2009 Hi,I have got some magura's front and back, but the back of my bike only has v-brake mounts.So does anybody know the cheapest place to get an evo 2 mount from.Josh. Quote Link to comment Share on other sites More sharing options...
fatty r Posted March 5, 2009 Report Share Posted March 5, 2009 should be able to get them from tarty bud Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 5, 2009 Report Share Posted March 5, 2009 should be able to get them from tarty budI dont think you can?CRC http://www.chainreactioncycles.com/Models.aspx?ModelID=291Thats all you need. Good luck. Quote Link to comment Share on other sites More sharing options...
MAX (M.A.D) Posted March 6, 2009 Report Share Posted March 6, 2009 (edited) I dont think you can?CRC http://www.chainreactioncycles.com/Models.aspx?ModelID=291Thats all you need. Good luck.+1, I ride the same set up but if you have a wide rim you will have to either buy a thinner rim or cut the inside bid and stretch it out and re-weld it as thats what I had to do.Edit: Sorry mistake I was talkng about the evo break booster and the addapter. Edited March 6, 2009 by MAX (M.A.D) Quote Link to comment Share on other sites More sharing options...
onza boy27 Posted March 15, 2009 Author Report Share Posted March 15, 2009 I don't get how you set them up though. Quote Link to comment Share on other sites More sharing options...
Jack Morton Posted March 15, 2009 Report Share Posted March 15, 2009 there easy to set up put you're calipers in the hole things and bolt on much easier then 4 bolt mounts Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 15, 2009 Report Share Posted March 15, 2009 pretty much the same to set-up as evo mounts.... comment my profile, may be able to point you in the right direction Quote Link to comment Share on other sites More sharing options...
