What Model And Year Is This?
staphan
Hey I'm new to Maguras and I'd like to know what model and year my brake is. It looks old :P
And the silver-coloured allen screw right next to the cable in the first image above, what does it do? Is it the bleeding screw or does it adjust how close pads are to rim?
Thanks in advance!
Thanks in advance!
You're right that it's old. My guess would be early 90's... 93,94 maybe? The silver allen bolt is the bleed screw. I *think* the flat head screwdriver bolt will adjust the pad position but I never ran this kind of Maggy so can't be sure.
ooh!
That's an hs22, ive got a pair of tomac ( flu orange ) versions of these....beasty brakes, 16mm master piston with a longer blade to compensate, making the power comparable to an hs33.
Good dependable brakes though.
The silver screw is simply a tpa bodge, it pushes the master piston in, and thus the pads closer to the rim..... only meant to be used for mid-ride adjustment though
Any more questions on this brake and ill try and help (Y)
Nah he says the allen key bolt, which I'm sure is just the bleed screw :)
I have a pair of them. Though i thought they were HS33s, can't remember why i thought that, i think it actually says so though. I also have a 'Classic' kicking about somewhere with the original bleed and round lever blade. Mine had clear blue hosing :D
Thanks for your replies ^_^
Actually, the guy I bought the bike from said they were HS33s as well so you might be right about that =)
Had some when i was younger im sure there really old hs33 :turned:
