AlexC101 Posted March 1, 2009 Report Share Posted March 1, 2009 Hi there i want to know if you can use any type of 20" rims on any type of 20" bike Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 1, 2009 Report Share Posted March 1, 2009 (edited) Hi there i want to know if you can use any type of 20" rims on any type of 20" bikeIf you were really tight kncickled then yeah, I guess. But renember, The majority of modern "20inch" trials bikes normaly have 19" rear wheels. Edited March 1, 2009 by Jack Chinnery Quote Link to comment Share on other sites More sharing options...
t-bird tom Posted March 1, 2009 Report Share Posted March 1, 2009 Any 19 inch wheel will fit any trials bike with a 19 inch rear wheel the same gose for frot 20 inch. Quote Link to comment Share on other sites More sharing options...
chrisbikefix Posted March 1, 2009 Report Share Posted March 1, 2009 only thing is i would make sure your brakes will adjust enough for the rims. If your using disc your fine, but maguras or v-brakes, just make sure the mounts are a good width apart ... if that makes any sense Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 2, 2009 Report Share Posted March 2, 2009 Any 19 inch wheel will fit any trials bike with a 19 inch rear wheel the same gose for frot 20 inch.Do they wont. Too wider rim and it wont fit. So you will have to go buy some offset mounts etc. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 2, 2009 Report Share Posted March 2, 2009 So long as the width is okay, and you've got a 19 on the back if needed...then it shoudln;t be a problem.Although, if you're talking about just changing the rims on a bike, the rims have to have a similar erd ( read size ) to the old ones, and also have to be the same spoke hole to build properly Quote Link to comment Share on other sites More sharing options...
t-bird tom Posted March 2, 2009 Report Share Posted March 2, 2009 Do they wont. Too wider rim and it wont fit. So you will have to go buy some offset mounts etc.Thats what george told me. Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted March 2, 2009 Report Share Posted March 2, 2009 Thats what george told me.He might not have known what you were fully on about. DX32 are quite wide rims. If you have fresh heatsinks. With a small frame you are pretty stuffed. Quote Link to comment Share on other sites More sharing options...
