Tartybikes Project Bike
AdamR28
I believe that triton is no more, shame really :(
My frame is 1585g, so lighter than the control to start with, I think it is a fair bit flexier than yours though, I need to run a rear 2bolt booster really. Ive topped 9kg so Im relatively happy, might put the BT forks back on to drop it down to 8.8 though :D
Im not sure if you could get away with a supersonic mountain king without a heavy tube, I think its got lighter sidewalls than a single ply maxxis :o
Lucky you, would love mine to be 1.58kg.
I used to run a Nobby Nic 2.4" on the rear which was 650g. Must have had around 20-30 snakebites in a month, after that i threw it away. It was the most awful, pinch happy tyre ever. Surely this Conti can't be any better seeing as it's actually lighter.
Also about the stiffness, have you tried removing the booster? When I got my frame it was flexy as f**k, brake wouldn't work at all. Even an Echo 4 bolt booster couldn't keep it from bending. After a few weeks of riding the brake started becoming more and more solid up to the point where the booster was no longer necessary. Now the brake is pretty much rock solid.
I've been running a Rubber Queen with a Maxxis Welterweight tube for about 4/5 months now, the tubes f**ked, I must have pinched it about 6/7 times, it's covered in patches now. :lol:
So I doubt it, I don't like the look of the tread pattern on the mountain kings either, I reckon the rubber queen would hook up on edges much better.
The Rubber Queens really are amazing. Mine is just about the grippiest tyre I've ever used, and looks like it's hardly worn at all, and I got it second hand. It's hardly even torn at the edges of the knobbles in the middle!
Ive run the rubber queen with a normal tube since october and its not pinched yet, to be fair I havent been riding as much as I would like :(
Ive got a mountain king on the front and it grips really well, I reckon it would work on the rear although perhaps not as good as the rubber queen (which I must agree with you is astonishing :D )
Its still pretty flexy with the booster on, bite is very good and not had any problems with hold so far, I prefer a softer brake as it eases the tendonitis in my brake fingers - Im also running an RB lever which always induces more flex; the brake booster is only 20g so I can afford to keep it for the weight :D
I will try it without when my new pad refills come through from heatsink.
I worked out a lightest mod spec and it was around 7.5kg due to the heavy tyres, not worth doing IMO.
The rear tyres are only bad if you are a basher. Gav has a Protection version (sidewalls are no thicker than the Supersonic) and only gets the odd flat, even though he rims out quite a lot.
The frame weight if this bike is 1.590kg.
I am quite sure this bike will not 'snap in 4 months of riding' either.
18t freewheel when 16t is available. Didn't go with the KMC hollow pin Kool chain in 3/32" then. Regular alloy top cap?
18t freewheels are much more reliable, gives better gear ratio, works better with the frame (for brake alignment mainly). The hollow pin chain is death, and the top cap is lighter than all the carbon ones I've ever seen (it's drilled).
I just questioned it because you decided to build a super light bike. I too wouldn't ride a 16t (on a trials bike) freewheel or hollow pin chain but it just means the extra bit of saving. I'd of thought 16/13 would come in close enough within 2mm ish? (i'm pretty much guessing)
[edit]
whoops!
Edited by eskimo
