stunt man t Posted February 21, 2009 Report Share Posted February 21, 2009 hey guys and girlsjust bin riding my bike today and noticed all of a sudden it was realy notcy and noiseysounded liek the chain was hubbing against the framebut when i inspected it closer i found out ti was the freewheelwhen u cock the pedals back it grinds and makes an aweful noise?is this common?or am i just unlucky?is there summet i can do to fix it?cheers Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted February 21, 2009 Report Share Posted February 21, 2009 Are you running a bash ring?If so take of off. Then there will be more clearance, Or you could just get a new bb. 128. Quote Link to comment Share on other sites More sharing options...
Chandler Posted February 21, 2009 Report Share Posted February 21, 2009 unlucky after all that work...sounds like u need a longer bb or a spacer of some sort in there?how was the ride, did anyone turn up? Quote Link to comment Share on other sites More sharing options...
stunt man t Posted February 21, 2009 Author Report Share Posted February 21, 2009 Are you running a bash ring?If so take of off. Then there will be more clearance, Or you could just get a new bb. 128.yes im running a bash ringits a try-all bb though aint that long enuf?????unlucky after all that work...sounds like u need a longer bb or a spacer of some sort in there?how was the ride, did anyone turn up? no one showed so i went home Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 21, 2009 Report Share Posted February 21, 2009 Mateys did this, pretty sure its the freewheel thats f**ked, rather than it rubbing on summat.Take it off the bb and see if it still does it. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted February 21, 2009 Author Report Share Posted February 21, 2009 Mateys did this, pretty sure its the freewheel thats f**ked, rather than it rubbing on summat.Take it off the bb and see if it still does it. bit simple that ok ill try it Quote Link to comment Share on other sites More sharing options...
stunt man t Posted February 21, 2009 Author Report Share Posted February 21, 2009 (edited) bit simple that ok ill try it done itand its definaly the freewheel i want to cry are the repairable?its only bin on since thursdaythats 3 day! Edited February 21, 2009 by stunt man t Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 21, 2009 Report Share Posted February 21, 2009 Nope you can't take them apart because they're welded.Send it back to whoever you bought it off if its new, if not thats plain old unlucky. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted February 21, 2009 Author Report Share Posted February 21, 2009 Nope you can't take them apart because they're welded.Send it back to whoever you bought it off if its new, if not thats plain old unlucky.i got it from tarty so ill phone them on mondaycheers for the help Quote Link to comment Share on other sites More sharing options...
