Onza T-pro
stunt man t
im not too sure as im not into weight if you get what i meen :P
but i cant see it being that hard.
well i get paid next week so i should be closer to my goal by then
and if u want you can have my echo lite forks, cus ill have some sl ones ;)
then u can be closer to youre goal aswell ;):giggle:
I only want front maggy because ive only ever tried disc and i fancy a change
plus every front maggy that ive seen has always been a beast :D
depending on if its set up properly :lol:
to be honest though i rode padariks gu and id agree wif you it was mighty fine
better then my disc :(
but if you want em you can have first dibs
they should be up for sale next weekend ;)
How is that so light? i dont see how :S Its not like its even got the lightest parts on it or what not.
think most of the weight i shuck off it was the bash plate mounts
when i cut em off i held the mounts and they must of weighd 400g easy
plus the plate weighed 200 g
and ive replaced it with a 19g bash ring ;)
So you're telling me this weighs 40g more than a Koxx Sky? I really don't see it myself. It's taken me so much hard work to get my Dob to 8.15kg, dunno how you can get this T-Pro to 8.8 so easily with a pretty standard spec.
Edited by JonMack
I was thinking the same, my stock is 8.95kg but thats using lightweight components pretty much everywhere. Have you actually weighed the bike?
forks = echo lites (drilled at the top 5x8mm holes and shortend as much as possible so has no spacers)
bars = onza carbon
frame = t-pro ( nitro mors'd,cut head tube, fully removed bash plate, mounts and drilled bb housing, 2x 8mm holes in drop-outs drilled)
cranks = monty 221 ti, echo SL bash ring, try all 108.9 freewheel, trial tech magnesium pedals (going to have trial tech bb and echo sl crank bolts tomorrow)
wheels = try-all rims frt and back, frt onza hub, rear viz! hub
but added a try-all bb and SL crank bolts
and drilled the stem (Y)
