Help With Gu Hub?
bigc
hi there i need some help with my gu hub, right when you pedel forward the cog on the back just spins i checked the lock ring thats nice and tight.
the hub is about 3 months old nd is standerd 26" frame hub. thanks for eney ideas or eney ideas i can try to mend it thanks
Naa. The ratchet ring has ripped out. Wherever you got it from contact them and let them know. Your hub is broken and you should be able to get a refund/payment towards another hub depending on how long you have had it. If your going to get a freehub get a Hope Pro II
