Andrew Willis Posted February 17, 2009 Report Share Posted February 17, 2009 hi lads, is a lock ring screw on or do you have to prise it off, im trying to get a lockring off a eno freewheel but the bugger wont mov, cheers Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 17, 2009 Report Share Posted February 17, 2009 It unscrews, see the ODNU bit written on it, theres an arrow pointing to the left in a clockwise motion.Undo it that way.Use either: Needlenose pliers or hammer and drift or pin spanner or whatever you can fit in there to turn it with. Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted February 17, 2009 Report Share Posted February 17, 2009 It unscrews, see the ODNU bit written on it, theres an arrow pointing to the left in a clockwise motion.Undo it that way.Use either: Needlenose pliers or hammer and drift or pin spanner or whatever you can fit in there to turn it with.I used small modelling screwdrivers and a hammer to get mine off. x Quote Link to comment Share on other sites More sharing options...
Muel Posted February 17, 2009 Report Share Posted February 17, 2009 Won't they chew the holes up?I use an old centre punch, it's really blunt now so barely leaves a mark, and you can hit it really hard so you can get the lockring mega tight. Quote Link to comment Share on other sites More sharing options...
