Freewheel Float?
Captain Scarlet
I'm sure most of your know the term "freewheel float", which on a front freewheel, becomes apparent when you spin your cranks backwards and you can see a side to side wobble to the freewheel (or float in this case). My first question; what actually causes freewheel float?, I understand the workings and internals of the freewheel, but have never known as to why most freewheels have float to them.
Secondly with my freewheel, the side to side motion is apparent, I also have an incredibly noticeable up and down movement to my chain when the freewheel is not engaged (in freewheeling state).
I've had this problem for sometime, and dismissed it as chain stretch, but its getting ridiculous now, especially when getting chain tension.
I shall be replacing my chain soon (and rear cog just to eliminate the possibility of very quick chain wear), but if this does not cure the problem is there anything else that can be done..?
Also, the freewheel is a Try-All one and the lockring doesn't appear to be loose, so I can't dismiss it as the actual cog moving from side to side.
firstly, its important to note (as I think you already know judging from your intelligent post) Your freewheel is NOT broken. It is as you say, a well known thing (although the terminology is new to me)
As Nick's said I've heard its down the how parallel the threads are machined against the crank. Im sure I read somewhere of a crank that was manufactured in a different way so as to reduce/remove freewheel float. But also the freewheel itself has some effect on it too. This bit Im not clear on, maybe onza or another manufacturer can clear this up?
Some freewheels float alot, I've seen monty freewheel's boogie-ing like mad whereas ENO's tend to be a bit more tame
Edited by PaRtZ
As Nathan (who is nathan?) said I've heard its down the how parallel the threads are machined against the crank. Im sure I read somewhere of a crank that was manufactured in a different way so as to reduce/remove freewheel float. But also the freewheel itself has some effect on it too. This bit Im not clear on, maybe onza or another manufacturer can clear this up?
Quoted for Fail, sorry Matt :P
Adam
