Guest Posted February 16, 2009 Report Share Posted February 16, 2009 i split my top cap last night so obv i would need to buy a new one , but it wont be here for tomorow ( it is a slanted top cap) so if i bought a normal stem rather than the monty slanted stem would it workd due to my forks being cut at a salnt ? please help me on this i need to know for tomorow please Quote Link to comment Share on other sites More sharing options...
Revolver Posted February 16, 2009 Report Share Posted February 16, 2009 So long as none of the steerer tube pokes out, it would work, but it's not ideal.Maybe just buy the top cap and do without until then. Quote Link to comment Share on other sites More sharing options...
Jack_M Posted February 16, 2009 Report Share Posted February 16, 2009 You could also bodge it up if you're desperate. You could either try using a long bolt and a normal top cap to tension the headset (no ideal but i've seen it done). Or you could follow this thoroughly dodgy but apparently effective method... http://www.observedtrials.net/vb/showthread.php?t=39281But yeah a new topcap is the long term solution. Quote Link to comment Share on other sites More sharing options...
Muel Posted February 16, 2009 Report Share Posted February 16, 2009 Once the stem bolts are done up, you don't need a topcap, it's only to tension the headset then the stem bolts hold it in place.Tarty will easily get it to you by tommorrow morning if they have any in.My brother ran slash cut forks with a flat top stem for ages, it just needs to be inside the stem.I'd just miss the ride though if I were you, buying a new stem is a bit extreme... Quote Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2009 Report Share Posted February 16, 2009 im not really a great fan of stem so ... i tried running it with out a top cap last night but everything felt loose. and my parents wants nothing to do with the bike so i doubt that they would buy something for it how ever little it cost them or me. Quote Link to comment Share on other sites More sharing options...
