Hs33's
Luke_zoo
What if I used Hope mono oil..? Like DOT 4? Would it affect my hs33 or do anything to the seels, whats it like? Spongy?
hope oil i don't know i still think its a DOT oil , DOT 4 oil will blow your seels . if you go in to your local halfords you can get normal mineral oil (the stuff I'm using) which will do the trick nicely
Bike hut is doing its own mineral oil now .
The stuff I'm using is called specialist mineral fluid ,The item no is 622027
Edited by Gogz-
Cheers.
mineral oil?
Can i use this in magura's ?
Cheers.
mineral oil?
I wouldn't want to tell you it will 100% work in-case it fu@ks up you maggy's. I can tell you the one that I stated in my other reply hasn't yet given me any problems.
As far as I'm aware it should work, It didn't say that there was any difference between the different mineral oil's I personally checked.
I checked the consistency between magura royal blood, monty oil and the one I bought and I couldn't tell the difference.
Edited by Gogz-
As long as its mineral oil, it should be ok? And not rot the seeals ect... ?
As the title says....
I'm sure you took part in the other topic in which someone asked "Does DOT 4 work?"
Cheers.
mineral oil?
I used that... It feels OK, it's really thick though. If you want value for moneym use some Citroen mineral oil. Tis like £9 for a litre from halfords.
