Balman Posted February 11, 2009 Report Share Posted February 11, 2009 Basicly I took my wheel out of my frame and my bolt is jamed in the hub iv attempted to take it out but in order to do that i need to grip both parts of the axle and i havn't got anything to grip it with iv tryed puting the wheel back in my frame and undoing the bolt but its not happening any suggestions at all? I know I sound like a NOOB but im genuinly stumped had a few people try at it now but I can't grip both sides of the axle to losen the bolt.Any help appreciated,Jack. Quote Link to comment Share on other sites More sharing options...
Elliot Posted February 11, 2009 Report Share Posted February 11, 2009 Basicly I took my wheel out of my frame and my bolt is jamed in the hub iv attempted to take it out but in order to do that i need to grip both parts of the axle and i havn't got anything to grip it with iv tryed puting the wheel back in my frame and undoing the bolt but its not happening any suggestions at all? I know I sound like a NOOB but im genuinly stumped had a few people try at it now but I can't grip both sides of the axle to losen the bolt.Any help appreciated,Jack.If it is the correct side could try a chain whip to hold the hub. Although I think it would only work for one side and I cant figure out which sitting in front of a computer at work! Quote Link to comment Share on other sites More sharing options...
Muel Posted February 11, 2009 Report Share Posted February 11, 2009 If it is the correct side could try a chain whip to hold the hub. Although I think it would only work for one side and I cant figure out which sitting in front of a computer at work!That wouldn't stop the axle turning though would it. I'd try putting the other bolt in a dropout and doing the other bolt up tight, then the axle should be locked up and you can get some force on the stuck bolt. Quote Link to comment Share on other sites More sharing options...
Mikee Posted February 11, 2009 Report Share Posted February 11, 2009 I'd try putting the other bolt in a dropout and doing the other bolt up tight, then the axle should be locked up and you can get some force on the stuck bolt.That's what I would do too. If all else fails, take it a bike shop and they will do it for you. Quote Link to comment Share on other sites More sharing options...
Balman Posted February 11, 2009 Author Report Share Posted February 11, 2009 Tryed that and the other side is still spinning possably a snaped axle? Bike shop? phha look at it hmm broken what you need is this brand new shimmano hub 10hole engement points and only set you back £100 lol Quote Link to comment Share on other sites More sharing options...
Muel Posted February 11, 2009 Report Share Posted February 11, 2009 I'd strip it and see whats what next, if the axle has snapped, you can easily send it back to hope and they'll probably send out a new one on warrenty. Sending the axle alone will save you having to debuild the wheel.I'd say it sounds like a snapped axle, but you need to strip it first to see what's wrong. Quote Link to comment Share on other sites More sharing options...
Andrex Posted February 11, 2009 Report Share Posted February 11, 2009 Balman, tomorrow I'll be riding my trials bike to college (duno why lol) so gimme a call when your free and I'll come check it out. It does sound like your axle has snapped though. Quote Link to comment Share on other sites More sharing options...
Balman Posted February 11, 2009 Author Report Share Posted February 11, 2009 Cant take the axle out i need to get the bolt out in order to do so gay thing had to happen as a new bike was mid build Quote Link to comment Share on other sites More sharing options...
eskimo Posted February 12, 2009 Report Share Posted February 12, 2009 Try some grease next time if you hadn't put any in before?Bolts are like £3 so i wouldn't worry about damaging them. Quote Link to comment Share on other sites More sharing options...
Simpson Posted February 12, 2009 Report Share Posted February 12, 2009 Jack I will summirise after my detailed inspection...You f**ked boyo!Snapped axel i think? Quote Link to comment Share on other sites More sharing options...
Elliot Posted February 12, 2009 Report Share Posted February 12, 2009 Jack I will summirise after my detailed inspection...You f**ked boyo!Snapped axel i think?After giving it thought with my brain actually in my head today, and having watched http://www.hopegb.com/page_mep_force_37.html, I agree, your boned.Email/ring hope, don't risk buggering it up anyfurther, just speak to them then you'll probably have to send it off. Quote Link to comment Share on other sites More sharing options...
Balman Posted February 12, 2009 Author Report Share Posted February 12, 2009 Thanks for your help everyone got a few pro2 bolts laying about might just chop it off an see if i can get it out? Bugga thanks everyone. Quote Link to comment Share on other sites More sharing options...
Otacon Posted February 12, 2009 Report Share Posted February 12, 2009 Whilst on the discussion of Hope pro 2's, If your hub shell splits or you have a problem with the internals on a Hope pro 2, do you need your reciept to send it off to Hope and get it fixed ? Quote Link to comment Share on other sites More sharing options...
Balman Posted February 12, 2009 Author Report Share Posted February 12, 2009 Don't see why you should have to as its not like it would have come from anywere else its clearly a hope product and they were factory faults too i might be wrong though but im pretty sure you can just send it away. Jack Quote Link to comment Share on other sites More sharing options...
Waynio Posted February 12, 2009 Report Share Posted February 12, 2009 take the 1 bolt out you can get out then knock the axle out in the opposite direction bud. you SHOULD be able to do that, it may pop the freehub body out etc. but thats my tip of the day.and if you need a new axle iv got a couple kicking around???? if you have got a few quid and a couple of hope wheel bolts il do you a swop+cash deal for a new axle if thats what you needed to replace???Wayne Quote Link to comment Share on other sites More sharing options...
Simpson Posted February 12, 2009 Report Share Posted February 12, 2009 Hes got his 74 kings and stuff on as well so can't pull it through Quote Link to comment Share on other sites More sharing options...
dave85 Posted February 12, 2009 Report Share Posted February 12, 2009 Surely there's enough space to get a hacksaw down behind the bolt head, cut the head off and then get the axle out. If it is really stuck, get the axle in a lathe and carefully drill the bolt out. Quote Link to comment Share on other sites More sharing options...
Netherking Posted February 12, 2009 Report Share Posted February 12, 2009 I'd strip it and see whats what next, if the axle has snapped, you can easily send it back to hope and they'll probably send out a new one on warrenty. Sending the axle alone will save you having to debuild the wheel.I'd say it sounds like a snapped axle, but you need to strip it first to see what's wrong.yep we send all send all broken hope products straight back to them. they usally replace all unfixable bits. Brill guys at hopeor ring them ur self! Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted February 12, 2009 Report Share Posted February 12, 2009 put the axle in a vice and undo the bolt thats what i had to do on my king when this happned Quote Link to comment Share on other sites More sharing options...
Damon W Posted February 13, 2009 Report Share Posted February 13, 2009 whack it with a hammer! Quote Link to comment Share on other sites More sharing options...
