Are Spacers Good For Boosters?
zoster
Normally, the booster doesn't actually fit and work properly without using the spacers. For example, on a 4bolt magura one, if it has no spacers the curvature of the clamp means, well, you need spacers.
So use them, it's designed for them, unless you really can fit and fully use it without the spacers, in which case, whatever you like.
Depends how stiff you want it, if it fits and works fine without the spacers then by all means do it. It will probably make the brake slightly stiffer and make it sit lower to the frame and look cleaner.
that's what i thought
thanks for the replies
