TheChai Posted February 9, 2009 Report Share Posted February 9, 2009 Hi guys, Has anyone found a decent alternative for the eno lockring? one that doesnt get threaded as easily? Would an ACS or any other freewheel lockring fit? ( before i start buying mulitple ones and taking them apart) or a nut of some sort? i would really prefer if it didnt have anything to do with permanent welding. Any help would be great, Trying to service my ENO is proving far too costly =(.. ThanksAndrew Quote Link to comment Share on other sites More sharing options...
EchoSam Posted February 9, 2009 Report Share Posted February 9, 2009 Best freewheel you can buy = tensile! Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted February 9, 2009 Report Share Posted February 9, 2009 I'm also in the same boat with my Echo Fw, i'v tried the lockrings from a Dicta ( ), an Acs and neither worked Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted February 9, 2009 Report Share Posted February 9, 2009 Would a tensile one fit?And have you used locktight? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 9, 2009 Report Share Posted February 9, 2009 I can usually get mine on ok if I'm careful, but getting them to stay on is a different matter...Even after supergluing one on it came off after 3 rides No idea how either, as freewheeling tightens it up in effect, and it isn't rubbing on anything. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 9, 2009 Report Share Posted February 9, 2009 anyone tried ptfe tape? Quote Link to comment Share on other sites More sharing options...
weirdoku Posted February 9, 2009 Report Share Posted February 9, 2009 I used a bit of Pritt Gel glue on my eno lockring. This glue dries like hard jelly and the lockring hasn't come off since. I can still unscrew it if I needed to. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted February 9, 2009 Report Share Posted February 9, 2009 I was about to buy one of these, are they any good apart from that?Can you not just stake the ring a little bit with a punch?Matt Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 9, 2009 Report Share Posted February 9, 2009 Best freewheels going, some are fine lockring wise and some arn't.One of mine keeps coming undone no matter what I do to it, one has been fine running without any locktite and has never come undone.Neither have ever skipped. Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted February 9, 2009 Report Share Posted February 9, 2009 The design needs to be revamped a bit, theres like 2 threads to hold the lockring on with, its ridiculous.I always dabbed a bit of bearing lock on the threads (like threadlock but stronger), and then cranked it to the max with a hammer.Give it a month and it would still come off, but it was better than no bearing lock at all. Quote Link to comment Share on other sites More sharing options...
