sam singlehurst Posted February 8, 2009 Report Share Posted February 8, 2009 hi people i was wondering if anyone had the water in their maguras freeze with a water bleed ??and what do you gain from an oil bleed ??thanks Quote Link to comment Share on other sites More sharing options...
brick_top Posted February 8, 2009 Report Share Posted February 8, 2009 Bleeding with water isn't good, 'cause there is no greasing effect. Go for Magura Royal Blood. It is designed for Magura's brakes. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 8, 2009 Report Share Posted February 8, 2009 Magura internals are plastic, so the water doesn't corrode them!A good water:anti-freeze mixture works fine in the cold weather. If you really want an oil bleed, just get some mineral oil, NOT DOT fluid, as that will ruin the seals on the pistons. Magura Royal Blood is just mineral oil in a fancy bottle. Quote Link to comment Share on other sites More sharing options...
pogo Posted February 8, 2009 Report Share Posted February 8, 2009 A good water:anti-freeze mixture works fine in the cold weather.+ 1 Quote Link to comment Share on other sites More sharing options...
bigamac Posted February 8, 2009 Report Share Posted February 8, 2009 Bleeding with water isn't good, 'cause there is no greasing effect.So how come so many riders use water?A good water:anti-freeze mixture works fine in the cold weather.+1And with oil you get a spongy feeling on the lever. Some riders like myself prefer water because its a smooth pull on the lever. Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted February 8, 2009 Report Share Posted February 8, 2009 No antifreeze for me, Slowly eats your seals. Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted February 8, 2009 Report Share Posted February 8, 2009 bollocks does it f**k your seals, i have always ran my brakes with anti freezeand water in the winter, and i have had the same slaves for ages. only reason i get a new body is beacause i snap them. my brake is fine and it always wil be with a little anti freeze.anti freeze + water *** Quote Link to comment Share on other sites More sharing options...
neonneon Posted February 8, 2009 Report Share Posted February 8, 2009 Mine froze this morning.Squeezed it a bit and it was fine...Been in there, same bleed for over a year...Do it!Water > OilCharlie Quote Link to comment Share on other sites More sharing options...
t-bird tom Posted February 8, 2009 Report Share Posted February 8, 2009 Or you could use monty brake oil. Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted February 8, 2009 Report Share Posted February 8, 2009 Well i've got diloot orange juce in mine haa Quote Link to comment Share on other sites More sharing options...
neonneon Posted February 8, 2009 Report Share Posted February 8, 2009 Well i've got diloot orange juce in mine haaThats just f**king stupid...Orange contains sugar... Douche.Charlie x Quote Link to comment Share on other sites More sharing options...
Muel Posted February 8, 2009 Report Share Posted February 8, 2009 I use this stuff called Silkoline Pro Cool. It's a coolant designed for motorbike engines, so it's designed not to corrode aluminium or eat through seals. It's slightly heavier to pull than water, but not a fat lot, and it's safe down to -32 degress according to the bottle!A litre of it is like £6-7 aswell so it will do about 15 brakes I reckon. I've done 2 recently and used about 100-150ml, loads left in the pot I put under the drain tube on the lever. Quote Link to comment Share on other sites More sharing options...
JJhey Posted February 8, 2009 Report Share Posted February 8, 2009 I think that water makes the lever feel quite good and normal magura oil feels quite stiff . What does the orange juice feel like? Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted February 8, 2009 Report Share Posted February 8, 2009 Thats just f**king stupid...Orange contains sugar... Douche.Charlie xWorks though Had nothing els on me when i was out riding Quote Link to comment Share on other sites More sharing options...
sam singlehurst Posted February 8, 2009 Author Report Share Posted February 8, 2009 Well i've got diloot orange juce in mine haa now thats thinking on the spot lol what does it feel like ??? Quote Link to comment Share on other sites More sharing options...
A.Baxter Posted February 8, 2009 Report Share Posted February 8, 2009 Water is fine it freezes just bring it inside for 5 minutes and it will unfreeze. Then just make sure you keep the brake moving all day until the temperature warms up. Anti-freeze eats away at hosing and seals :\Adam Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 8, 2009 Report Share Posted February 8, 2009 Water is fine it freezes just bring it inside for 5 minutes and it will unfreeze. Then just make sure you keep the brake moving all day until the temperature warms up. Anti-freeze eats away at hosing and seals :\Adam Then it'll freeze again... And WILL NOT thaw until the temp rises above 0C, no matter how much you keep pulling itUse I use windscreen/wiper fluid. Works a treat! Quote Link to comment Share on other sites More sharing options...
neonneon Posted February 8, 2009 Report Share Posted February 8, 2009 If it's cold enough to freeze your brake it's bound to be icy out anyway, so it's doubtful you'll ride in the ice. Please stop going on about it!!!Just bleed it with water or oil! If you really wan't to ride in sub zero temperatures, antifreeze it!! End-of really!!Charlie Works though Had nothing els on me when i was out riding Lmfao!!Well, if you find yourself stranded with your bike on a desert island with your bike, you have a little refreshment.. lolCharlie x Quote Link to comment Share on other sites More sharing options...
its mark Posted February 8, 2009 Report Share Posted February 8, 2009 If it's cold enough to freeze your brake it's bound to be icy out anyway, so it's doubtful you'll ride in the ice. Please stop going on about it!!!Just bleed it with water or oil! If you really wan't to ride in sub zero temperatures, antifreeze it!! End-of really!!Charlie Lmfao!!Well, if you find yourself stranded with your bike on a desert island with your bike, you have a little refreshment.. lolCharlie xWell Said Charlie ! Quote Link to comment Share on other sites More sharing options...
neonneon Posted February 8, 2009 Report Share Posted February 8, 2009 I use this stuff called Silkoline Pro Cool. It's a coolant designed for motorbike engines, so it's designed not to corrode aluminium or eat through seals. It's slightly heavier to pull than water, but not a fat lot, and it's safe down to -32 degress according to the bottle!A litre of it is like £6-7 aswell so it will do about 15 brakes I reckon. I've done 2 recently and used about 100-150ml, loads left in the pot I put under the drain tube on the lever.Muel, it's lighter isn't it!? We know the real reason!!! Charlie xWell Said Charlie ! Haha! Sorry if it sounded like a rant. I was just expressing my thoughts, (as many members will know) I'm not very good at doing that without upsetting people (but I will no longer express any opinions on this forum related too a certain type of computer... Charlie x Quote Link to comment Share on other sites More sharing options...
onza-ian Posted February 9, 2009 Report Share Posted February 9, 2009 I've used vegetable oil for a while because i didn't have any mineral brake fluid. works quite well actually Quote Link to comment Share on other sites More sharing options...
neonneon Posted February 9, 2009 Report Share Posted February 9, 2009 I've used vegetable oil for a while because i didn't have any mineral brake fluid. works quite well actually LOL, Sounds like it would to be honest.What about bleeding your brake with 100% antifreeze?Charlie Quote Link to comment Share on other sites More sharing options...
onza-ian Posted February 9, 2009 Report Share Posted February 9, 2009 Never tried it , or thought about trying it to be honest , i dont see a problem with just using magura blood.Although the flora vegetable oil is still circulating in my front brake :L i cant be arsed changing it. Quote Link to comment Share on other sites More sharing options...
neonneon Posted February 9, 2009 Report Share Posted February 9, 2009 Never tried it , or thought about trying it to be honest , i dont see a problem with just using magura blood.Although the flora vegetable oil is still circulating in my front brake :L i cant be arsed changing it. Water feels MUCH nicer, its free, its easy and its more responsive.Charlie Quote Link to comment Share on other sites More sharing options...
Muel Posted February 9, 2009 Report Share Posted February 9, 2009 Muel, it's lighter isn't it!? We know the real reason!!! Charlie xNo, I just got bored of my borrowed maggy freezing up. Quote Link to comment Share on other sites More sharing options...
