PaulM Posted February 6, 2009 Report Share Posted February 6, 2009 Hi,I would like to top up the brake fluid in my echo tr hydraulic brakes as I suspect they have a bit of air in them. The echo website only says to use mineral oil. My questions are:1. What type/brand of mineral oil should I use?2. Where can I buy the oil? (eg. a regular bike shop here in New Zealand?)Thanks,Paul Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 6, 2009 Report Share Posted February 6, 2009 magura mineral oil will do fine...although as that is pricy; you can use citroen clutch fluid ( exactloy the same stuff, although im not too sure how easy the latter would be to buy out where you are ). Quote Link to comment Share on other sites More sharing options...
PaulM Posted February 6, 2009 Author Report Share Posted February 6, 2009 Thanks Alex - much appreciated.Cheers,Paul Quote Link to comment Share on other sites More sharing options...
freetrial Posted February 7, 2009 Report Share Posted February 7, 2009 Shimano mineral brake fluid is also great. Quote Link to comment Share on other sites More sharing options...
