Laptop Screen Issues
Joe Papasnap Maher
Laptop os f**king up big time.
Basically, Just turned it on this morning and the screen was f**ked..I can see like split screen..
Same thing top and bottom.
im currently in safe mode with netoworking, as normal mode just gets to a certain point upon loading and the screen just goes black..almost like its not on.
What the f**k is up with it??:S Monitor issues??
I have a 3 year warranty on this with dell, but bascially sending it back home, and what not is asking for more trouble..
Any ideas..
Ive added a print screen..but weirdly enough..it doesnt show the bottom half?? But where its all white..is a duplicate of the top??
Hmmm, not forced to be your graphics, it could be a power problem.
Does the same thing happen when running on AC and battery?
Does it duplicate going through the POST screens or just when XP has 'loaded'?
Have you dropped it lately or been in a situation where you may have blocked airflow?
Have you tried attaching an external monitor to the laptop to see if it still persists (obviously not a fix for it, but it'll help troubleshooting)?
Duplicates from startup..
Nope not dropped it lately..Not blocked airflow much..and if the bottom gets warm i always lift it up.
Dont have another moniter to attact to..
I havnt tried starting up normalaly with it plugged in. Will restart and try again.
Back in 5-10
Same thing happened to my old laptop...was much too old to bother fixing but i plugged an old crt monitor into it and it worked fine! If your looking for a quick fix....
Unfortunatly..i cant carry a monitor around with me all the time lol :P
plugged in makes no diffrence. Cant even get back in safe mode. Currently on my phone haha. It sais at the mo, attepting to repair disc errors... This may take an hour to complete. What do i have to press to start in safe mode?
that did nothing. So f**king annoyed cant even get in safe mode..
f**k sake. Its working again now, fine and dandy. No battery in..just the plug.. No split screen. Its fine..
But give it 5 mins, and it will freeze and just die again.. Will update in 5, to tell u if its still alive lol.
Strange that it works fine without the battery in - more than likely what I first thought with a dodgy power supply.
But then again that wouldn't explain why it wouldn't boot in safe mode...unless dodgy power to the hard drive would cause such a problem.
Keep posted :)
Edited by Baby Pizzle
Kept it on all night..woke up..all still working perfect.
20 mins internet use and screen went black.(Possible lack of air to the underside..but no diffrent to normal?? ) I pressed the power button, turned it off and on..
When it came on, its split screen again.
Why is it being such a fanny.
