JTM Posted February 2, 2009 Report Share Posted February 2, 2009 Its the little square silver one just to the right of the middle of the pic. Its dying. How do I get it off? And where can I get a replacement fan? Thanks Quote Link to comment Share on other sites More sharing options...
forteh Posted February 2, 2009 Report Share Posted February 2, 2009 There is usually a little plastic pushpin either side of the fan, you should be able to dismount the entire heatsink and replace it for 5-10 quid You might need to take the motherboard out of the case though, have a look and see if you can release it without doing so. Replacements can be bought from overclockers.co.uk, you need a northbridge heatsink/fan; either a passive (quieter) or active (more effective) solution should be available. Quote Link to comment Share on other sites More sharing options...
JTM Posted February 2, 2009 Author Report Share Posted February 2, 2009 http://www.overclockers.co.uk/showproduct....&subcat=818That all I need? Quote Link to comment Share on other sites More sharing options...
Danny Posted February 2, 2009 Report Share Posted February 2, 2009 I put one of these on my old motherboard when the fan died....http://www.overclockers.co.uk/showproduct....&subcat=399You'll have to take the motherboard out to fit it though. Quote Link to comment Share on other sites More sharing options...
JTM Posted February 2, 2009 Author Report Share Posted February 2, 2009 Not sure if that will fit under my graphics cards fan wire thing? Is that all I need or does it need thermal paste under it etc? Quote Link to comment Share on other sites More sharing options...
forteh Posted February 2, 2009 Report Share Posted February 2, 2009 If you can unscrew the current fan from the northbridge heatsink then you should be able to replace it with the 40mm fan you linked to, if not (I know some mobos have the fan sort of integrated into the heatsink) then you will need to replace the heatsink; if so you will need some thermal paste.Fromthe photo it looks as though yours is an integrated fan/heatsink, you can always try to resurrect the fan by cleaning it out with some electrical contact spray cleaner, you should get it off the motherboard first though Quote Link to comment Share on other sites More sharing options...
