Luke_zoo Posted February 1, 2009 Report Share Posted February 1, 2009 I have a back echo brake and a frunt hs33 04 style i've gone back to the back hs33 04 style whats the difference with pulling and that and bleeds?would it slip or not i know my echo used to slip alot though, not sure if it was a good idea? any advice?I cannot run a booster? as i have m6 mounts now Zoo python 07 Cheers luke Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted February 1, 2009 Report Share Posted February 1, 2009 Search feauture. Quote Link to comment Share on other sites More sharing options...
Callum.Curwood Posted February 1, 2009 Report Share Posted February 1, 2009 Search feauture.Have you got something to say in everyones topics?Back to topic:The echo brakes and Maguras have the same function really.It all depends on how good the bleed is.Also it might of been the pads that made it slip, using certain pads on a certain rim surface will improve braking alot.But Echo brake do tend to leak alot, so stick with the 04. Quote Link to comment Share on other sites More sharing options...
Jack Chinnery Posted February 1, 2009 Report Share Posted February 1, 2009 Have you got something to say in everyones topics?Back to topic:The echo brakes and Maguras have the same function really.It all depends on how good the bleed is.Also it might of been the pads that made it slip, using certain pads on a certain rim surface will improve braking alot.But Echo brake do tend to leak alot, so stick with the 04.Have you got to copy what Muel says? But put in different words.At least im not the one stuck in nmc. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted February 1, 2009 Report Share Posted February 1, 2009 (edited) Search feauture.and would of helped alot the brake to be honest are basically the same with the echo brake you have the 7% better braking due to the lever blade and the tpa goes real quick and you cant water bleed .the 04's are realy good brakes easy to fix due to the tpa bodge but you cant have a differnent style lever bladeso its all prefence realyedit id rather have callum in members as all you do is slag everyone off 'cos you think your cool Edited February 1, 2009 by Trisandhisbt Quote Link to comment Share on other sites More sharing options...
freetrial Posted February 1, 2009 Report Share Posted February 1, 2009 I`ve had magura -04 -05 - 06, Echo CNC and Echo SL. I`ve had no problem with leaks on any of these. Also, my best tip for bleeding is: Shimano mineral brake fluid. It keeps the seals tight, bleads easily, and runs lighter than magura blood.As for using a booster with M6 bolts, you can simply drill larger holes in your booster, and your good to go.Keep in mind, that the better the pads / grind are, the less power you will have to use on the lever, which in turn gives less strain on the seals, and the brake will be less prone to leaking!Rant over...Cheers! Quote Link to comment Share on other sites More sharing options...
Alex@Flawless Bikes Posted February 1, 2009 Report Share Posted February 1, 2009 Hs33 is better every one I know who as has an echo brakes says they leak like mad and when they do work they don't feel very nice! Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted February 1, 2009 Author Report Share Posted February 1, 2009 Hs33 is better every one I know who as has an echo brakes says they leak like mad and when they do work they don't feel very nice!Oh right well i've gone back to 04maggie and had a ride and now my brakes have frozen up due to snow Quote Link to comment Share on other sites More sharing options...
Callum.Curwood Posted February 1, 2009 Report Share Posted February 1, 2009 Oh right well i've gone back to 04maggie and had a ride and now my brakes have frozen up due to snow Bit of anti-freeze will sort you out Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted February 1, 2009 Author Report Share Posted February 1, 2009 Bit of anti-freeze will sort you out Yeah just dent have any before i went riding but i think i'm going to go back to magura blood Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 1, 2009 Report Share Posted February 1, 2009 Search feauture. Quote Link to comment Share on other sites More sharing options...
Callum.Curwood Posted February 1, 2009 Report Share Posted February 1, 2009 No Ben! Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 1, 2009 Report Share Posted February 1, 2009 But he is... Legend of the n00bs Quote Link to comment Share on other sites More sharing options...
Muel Posted February 1, 2009 Report Share Posted February 1, 2009 Have you got to copy what Muel says? But put in different words.At least im not the one stuck in nmc.It's not just me, or are you missing something? It just seems every topic has a shite post from you somewhere in it. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted February 1, 2009 Report Share Posted February 1, 2009 i know muel but ive spoke to him and he his gonna try and be kool so cut him some slack if not wel just carry on 'cos hes a noob Quote Link to comment Share on other sites More sharing options...
Callum.Curwood Posted February 1, 2009 Report Share Posted February 1, 2009 But he is... Legend of the n00bs What about me Ben! Quote Link to comment Share on other sites More sharing options...
neonneon Posted February 2, 2009 Report Share Posted February 2, 2009 HS33 - MaguraEcho Brake - DengEnough said?Nn Quote Link to comment Share on other sites More sharing options...
onza_basher Posted February 2, 2009 Report Share Posted February 2, 2009 i had an echo cnc front brake once never again looks amazing but leak like crazy after a thew months of having itand with every hs33 ive had not a single problem Quote Link to comment Share on other sites More sharing options...
am-i-bothered Posted February 2, 2009 Report Share Posted February 2, 2009 my dengura is spongy, need to bleed it. But I have already changed one slave cylinder as it leaked. Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted February 3, 2009 Author Report Share Posted February 3, 2009 my dengura is spongy, need to bleed it. But I have already changed one slave cylinder as it leaked.Yeah Dengs are like that. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 4, 2009 Report Share Posted February 4, 2009 i say magura 04 with rb blade.... looks pimp, and best of all...just works Quote Link to comment Share on other sites More sharing options...
