NVWOCI WVS Posted January 31, 2009 Report Share Posted January 31, 2009 Basically, I'm runing a magura on my Leeson with a chrome rim and some Plaz Spanish-Fly pads. The brake performs really well, but sometimes the pad just grips too hard on the rim and rips out of the backing. I've tried re-sticking it in with super glue, an even a little bit of thickened epoxy resin, but They keep coming out.I've just been out for a little ride now and it's finally had it. The actual pad material has torn this time (see photo). The brake is always well set up, with the pads square to the rim, and the trailing edge touching slightly first.Any tips or pad recomendations for this setup, which might last slightly longer than these? Thanks,Sam Quote Link to comment Share on other sites More sharing options...
N.Wood Posted January 31, 2009 Report Share Posted January 31, 2009 Try setting them up really close to the rim so theres not much room for it to actually catch and twist out? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted January 31, 2009 Report Share Posted January 31, 2009 They did the same when I had them on a smooth rim, I found them just too grippy. I switched to CRMs and it hasn't happened since. Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted January 31, 2009 Author Report Share Posted January 31, 2009 Try setting them up really close to the rim so theres not much room for it to actually catch and twist out?I set them up usind a credit card, so they were pretty close. Don't really think I could have them any closer.They did the same when I had them on a smooth rim, I found them just too grippy. I switched to CRMs and it hasn't happened since.CRMs on a smooth rim? I might give it a go. Quote Link to comment Share on other sites More sharing options...
Muel Posted January 31, 2009 Report Share Posted January 31, 2009 When you glued them back in with the superglue, did you fill the backings up with it?If not it could work, just to make sure that every bit of surface area that could be glued in is glued in. Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted January 31, 2009 Author Report Share Posted January 31, 2009 Superglue is a contact adhesive. It only works properly if you use a minimal ammount. I was pretty generous with it though, I'd say. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted January 31, 2009 Report Share Posted January 31, 2009 CRMs on a smooth rim are awesome! Maybe to bitey for street? Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted January 31, 2009 Author Report Share Posted January 31, 2009 CRMs on a smooth rim are awesome! Maybe to bitey for street?Well, it's a chrome rim, so I guess CRMs will be ultra aggressive. I might try a set of koolstop reds or magura blacks for a while... Does anyone want to give me a set for the price of postage, pretty please? I'm a skint student! Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted January 31, 2009 Report Share Posted January 31, 2009 Superglue is a contact adhesive. It only works properly if you use a minimal ammount. I was pretty generous with it though, I'd say.very true...remember this people...!! not alot of people seem to realise this- the bond from glue to surface is better than glue to glue...less is more! Quote Link to comment Share on other sites More sharing options...
guuuuuuuuu leeeeeeeee Posted January 31, 2009 Report Share Posted January 31, 2009 try grinding your rim slightlymy mate higgz pad stuck to his try all rim when it was smooth but grinded his rim now its in perfect working order (since last time i seen him) Quote Link to comment Share on other sites More sharing options...
NVWOCI WVS Posted February 1, 2009 Author Report Share Posted February 1, 2009 try grinding your rim slightlymy mate higgz pad stuck to his try all rim when it was smooth but grinded his rim now its in perfect working order (since last time i seen him) That would defeat the whole point of a chrome rim. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted February 1, 2009 Report Share Posted February 1, 2009 Superglue is a contact adhesive. It only works properly if you use a minimal ammount. I was pretty generous with it though, I'd say.Actually superglue will only stick without oxygen which is why it only works with thin aplications, you need to squeeze the oxygen out. That is why it doesnt go hard in the bottle.Blah blah blah ....wheres my wig?Matt Quote Link to comment Share on other sites More sharing options...
