Tribal Zone Posted January 30, 2009 Report Share Posted January 30, 2009 Here are the first pictures of a new Try All / No War Fork coming in spring...Exclu : la fourche No War ! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 30, 2009 Report Share Posted January 30, 2009 (edited) Here are the first pictures of a new Try All / No War Fork coming in spring...hole in the steerer tub? wow, hopefully this one isnt bonded and is a thick alloy steerer Edited January 30, 2009 by Alex Dark Quote Link to comment Share on other sites More sharing options...
forteh Posted January 30, 2009 Report Share Posted January 30, 2009 880g for a disk only fork with a hole in the steerer tube? My bt forks are 820g with disk and vee mounts! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 30, 2009 Report Share Posted January 30, 2009 880g for a disk only fork with a hole in the steerer tube? My bt forks are 820g with disk and vee mounts!...thats ridiculous, ubans are only 4g heavier Quote Link to comment Share on other sites More sharing options...
N.Wood Posted January 30, 2009 Report Share Posted January 30, 2009 What happens when the factory weld the disk mount on wonky? Quote Link to comment Share on other sites More sharing options...
Cookyboy Posted January 30, 2009 Report Share Posted January 30, 2009 (edited) What happens when the factory weld the disk mount on wonky?You will probably be f**ked!? just as much as you would be with their warranty stuff! all seems a bit bent this nowar stuff Edited January 30, 2009 by Cookyboy Quote Link to comment Share on other sites More sharing options...
