Do Juicy 3's Suck?
Bol Maaaaaaing
When I got my CZAR, It had both Juicy 3's, And the rear brake piston leaked. So I got it replaced,
The new one was good for a while, But has started to get bad, And when I took the pads out of it I found that that piston leaked too! :angry:
I was just wondering if anyone else has problems with their Juicy 3's?
And are they worth having?
Or am I just not doing something wrong?
Thanks,
Joe
Hopefully you've just been unlucky. Only thing I've seen go wrong with Juicy's so far is one lever in the 3 or 4 pairs people I know use has got a bit slow to return after it has been pulled.
If it's new get it sorted under warranty, if not the leak may be a bad caliper or piston rather than bad seals. I had the first (and last) Formula brake I'll ever buy leak at the pistons too come to think of it - Shimano brakes have given me no trouble in the 7 years since I bought my first set of XT 4 pots (Which are still running perfectly on my hardtail - the disks are worn quite thin though)...
I wouldn't have thought Juicy 3's were a good trials brake though.
Ok. Yeah, I got the whole thing replaced (Levers, Cables and Calipers) And thats still packed up. The oil leaks from behind the pistons onto the pads and disk.
I got the bike only about 3-4 months ago, So it will still be under warranty.
I know that the newest model CZAR's have Magura Louise's brakes.
Does turpentine work the same as Methylated Spirits?
I had them on my MTB and they progressively lost power until a few months later, squeezing the lever did nothing.
If you're planning on drinking them probably...
No thats really wrong.............
it's really hard to keep Turps down :lol:
Change your pads kook
Edited by Themechanicalbear
I mean for cleaning off oils from the pads and disk...
burn it off (Y) get your pads over the gas ring, hold them with pliers, and cook them till they're glowing. then douse (sp?) them in cold water. used to make my brakes work better...
Will that not wreak the pads?
What about the disks?
Fairy liquid and hot water on the rotor and blow torch/heat to a high enough temperature to burn the oil off the pads. Then dip the pads straight into cold water. Doesn't do tehm any harm.
That will sort them out.
Juicy threes are fine for what they wer intended for, i can't imagine them being any good on a trials bike.
The sudden temperature change from dropping the pads in cold water is not a stress the pads are likely to have been designed for - the mismatch between thermal expansion coefficients between the pad material and backing as well as the temperature gradients within the pad may lead to them cracking. To clean disks I use Isopropyl Alcohol (IPA) as it leaves no residue. With Pads if they're not badly contaminated I just run a file over the braking surface and it seems to do the job. Baking them in an oven or heating with a blow torch and allowing to cool in air should both be effective too.
If its under warrenty just send them back and as its the second time its happened tell them you don't want Juicy 3's again and ask for Magura Louise's - they're around the same price so i can't see it being a problem. My friend ordered Juicy 3's as he4 wanted some cheap discs for his hardtail and the shop he ordered from just gave him 180 Magura Louise's and said 'they're better' so its a fair trade.
No point messing around with something that caused you problems before - dont bother clenaing them either - not your fault, just send them back.
Magura Louise's cost a lot more than Juicy 3's. Julies are more comparable in price. I've never had trouble with Magura brakes (That I didn't get second hand for half nothing, with loads of miles or a known fault and a previous owner who adjusted them with a hammer)...
I'd go with Magura or Shimano from a reliability point of view if you want to stay with hydraulic brakes or Hope if you feel like spending 3 times as much as the Juicy 3...
Edited by psycholist
Yeah i meant Julies not Louise's.
I like my Louise a lot :)... I also like my dual control XTR levers with XT calipers and my 2002 4 pot XT disks (For which the total servicing consisted of adding a few drops of fluid to the reservoirs since I fitted them in 2002 and feeding them brake pads every 1500miles. The disks are starting to wear noticeably thin on them now, but they're still working perfectly)...
Would I be able to get a Louise as a replacement?
Or am I looking at paying extra too?
yes!juicy 3 really suck indeed!
i bought my juicy 3 brand new!at first it worked very well,very powerfull(with 185 rotor),but the piston leaked after just 1 month >_<
avoid juicy three!
Thats what happened to me!
This morning I looked at them and there was oil all over the disk!
There was more oil than disk!
The Louise is a bit under twice the price of the Juicy 3 IIRC, so you will have to pay extra. I weigh over 90kg and can wheel swap front to back onto things using a 160mm Louise on the front of a 26" bike (When I don't screw it up :P)... Thinking about going to a 185 disk to make gaps to the front wheel a bit easier alright though... 5 year leakproof warranty is a nice extra detail too - though I did have to put a few extra drops of fluid into the reservoir on mine before it would bite consistently as it was underfilled when I got it from Chainreaction.
