mikey Posted January 25, 2009 Report Share Posted January 25, 2009 hi all I havent posted on here for a couple of years but this week I got a onza, I have fitted my magura rim brakes I have also fitted the boosters but I would like to change to the 4 bolt mount so my questions are 1) do you have to different booster for these type of mounts 2) is there any 4 bolt mounts that are worth getting over others, I dont want to spend to much as il need some for the front and rear if links could be posted up that would be a great help.thanks mikey Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted January 25, 2009 Report Share Posted January 25, 2009 Does your frame have 4bolt mounts or Vee mounts?If it has 4 bolt mounts, they're all pretty much as good as each other...If it has vee mounts, you'll have to stick with the EVO mounts that you're using at the moment, sadly. Quote Link to comment Share on other sites More sharing options...
Smoby Posted January 26, 2009 Report Share Posted January 26, 2009 four bolt mounts or Vee mounts? Quote Link to comment Share on other sites More sharing options...
mikey Posted January 26, 2009 Author Report Share Posted January 26, 2009 four bolt mounts front and rear Quote Link to comment Share on other sites More sharing options...
T-vee Rider Posted January 26, 2009 Report Share Posted January 26, 2009 four bolt mounts front and rearAll 4-bolt mounts do the same job really, just some are lighter and more expensive.Standard Echo ones should be fine but if you really want to go fancy get some of the Try-all mounts or the Echo Tr mounts, they take the need of the plastic washers out so you just tighten your bolts and the pads set them selves up square to the rim The echo ones are cheaper then the try-all, so if your thinking about them, get the echo. Quote Link to comment Share on other sites More sharing options...
maxxis26 Posted January 26, 2009 Report Share Posted January 26, 2009 have a look on tarty bikes they have a great selection of boostershttp://www.tartybikes.co.uk/search.php?category_id=3there you go Quote Link to comment Share on other sites More sharing options...
mikey Posted January 26, 2009 Author Report Share Posted January 26, 2009 thanks for the help Quote Link to comment Share on other sites More sharing options...
