How Do You Put A Barbed Fitting On A Hose?
Cresswell_d
Ok, I broke my cross over and I have a few spears and some hose, I can make a temporary cross over untill I get a braided cross over.
But I have a problem I cant get the barbed fitting into the hose.
I have tried putting it in boiling water, melting it etc.....
So how do the people at magura do it?
Or
How do other people do it?
Please help with picture with out pictures!
Daz.
WRONG.
If you buy a magura bleed kit it comes with two funny black plastic blocks. You need these to put on the barbed fitting properly. That or to make yourself something that resembles them.
I know the block things becuase they sell them seporate on tarty. But in the magura factory im just imagining they use a machine?
Put my hose in vice, not to tight, and VERY gently tapped in the barb. Each tap look very closely what direction its slanting in, tap it back and carry on, mine is still working to this very day (Y).
You might have to practice a few times before mastering this xD.
I got it first time (Y).
Hope I've been a help to you (Y).
Craig.
Craig.
That actually really helped im gunna bare that in mind for when I
f**k
up my crossover
The thing with that though, is in order to have it in the vice tight enough to hold the hose in place, it will crush the hose, and if you crush the hose, you're not getting the barb in.
Yeah.. I had that exact problem. Started with a length of hose about 25mm long, and after messing it up so many times and having to cut it down, there was nowhere near enough to make a crossover! Just do what Muel said, or but the official magura blocks, as Bruce suggested!
