The Xbox 360 Problem Thread
ZHI-sam
This has really something to do with xbox live/my internet
When I play online my NAT is sometimes strict, so sometimes I can't join peoples partys/private chat/games/hear anybody
My internet is perfect and works all the time but it's annoying. Anyway to make it unstrict?
yea u need to log into your router to do it.
Step 1: Get your Xbox 360's IP address from the system blade and choose network settings. Then edit settings should show your Xbox's IP.
Step 2: Go into your routers configuration window through Internet Explorer. In the address bar type in your routers IP address. It should be default at 192.168.1.1 or 192.168.2.1. When you're prompted for a password you have found it =P. If you haven't changed it the username and password should both be admin, and admin.
Step 3: USING DMZ When you enter into your router config window, you need to find the Tab DMZ, it should be under applications and gaming if you are using Linksys. Once you find the DMZ tab, click enable and type in the last digits of your XBOX into the box below. Yes when you do this you are opening all the ports on your Xbox, which is insecure, but show me someone that has hacked into an xbox 360?
<MAKE SURE YOU SAVE SETTINGS>
Step 4:Using Port Fowarding After you have enabled DMZ, find the Port Fowarding tab, should be under advanced routing. For the name type in XBL or whatever you want, and for port range put 87 to 89, choose UDP, then your XBOX last digits, and enable. Then do 3073 to 3075 choose TCP, then your XBOX last digits, and enable. Then again do 3073 to 3075 choose UDP, then your XBOX last digits, and enable.
Step 5:Using UPnP This is just incase. Go into UPnP fowarding and enter in the same stuff you did for Step 4.
Step 6: Now logout of your router config. Unplug your router and modem from the power, then plug in the router 1st, wait 30 seconds. Then plug in the modem and wait at least 2 minutes. If you don't do these hard restarts it might not work!
Step 7: Restart your Xbox and go to the system blade, choose network settings, then test connection. This may take a bit, but when it gets down to NAT type it should say OPEN. If not, sorry. You can just undo all the settings we changed, you can just uncheck enabled on the port fowarding. or if you want to restore your router to the factory defaults just push the reset button on the back of it.
Edited by ZHI-sam
  • 1 month later...
Basically i bought the cod map pack a few weeks ago with nazi zombies, last night put it in and it came up with a message saying, "downloaded content is damaged."
Don't suppose theres any way to fix it, or if i email microsoft redownload it? Really don't fancy paying however much it was again, i'm only a skint student.
