Echo Control 09
t33zr
Frame set:
Frame: Echo control 2009 mod
Fork: Koxx Forxx
Drivetrain:
Bottombracket: Echo isis
Cranks: Try-All ISIS 165mm
Pedals: Try-All dubble cage
Chain: KMC
Freewheel: Try-all 109.8
Sprocket: Try-All Screw On
Rearwheel:
Hub: Try-All hOle
Rim: Try-All hOle (black)
Tyre: Try-All sticky
Frontwheel:
Hub: Try-All hOle Disc
Rim: Try-All hOle 28hole (black)
Steering:
Headset: Cane Creek
Stem: Try-All nuc
Bar: Try-All Rage Bar
Grips: Try-All foam
Brakes:
Frontbrake: Try-All
Rearbrake: Magura HS33 (Long lever)
Brakepads: Alubackings on coustpads
Total weight: 9.9kg
Did a few updates today:
Reartyre: Schwalbe big betty
Fronttyre: Schwalbe racing ralph
Pedals: Wellgo MG1 magnesium
Stickers: Koxx
Total weight now: 9.15 kg
Few updates still to come... i want it under 9kg! :)
BIG UPS to Adam and Crew at www.Tartybikes.co.uk :wub:
Edited by t33zr
165 cranks sound horrible, get some 175 on it and 15 tooth rear cog will be minto
I run 18T - 16T with 165 cranks... im a really small person, with short legs :P
I ride WAY better on short cranks... and i also save some weight :)
Why the koxx stickers?
The echo stickers sux, they ripped off after 2 hours of riding.... and i want to make a "look" on it, not just a clean bike
Great looking bike. I find it strange that you ride your bars with so much tilt forward. Anyways….I am glad to see you are back on a stock. Start filming!
Ive heard that before... the Try-All nuc stem is to short and to high for me, thats why....
I have no money for a trialtech stem yet, but i will deffo buy one... then i can tilt my bar more backwards and i also save 50-60g on it :)
Got a maxxis fly weight tube in the front? Only 90g.
I know they are realy light... but they dont last more than one tap ;)
There is a few small changes do be done....
Titanium pedals, remove rimtape, trialtech stem, cut some knobbs....
let your angle grinder get a bit intimate with your seat tube?
  • 5 weeks later...
